MINI R53 s
Discussion in 'Starting Line - New Member Introductions' started by Noah l, Feb 16, 2018.
  1. Noah l
    Noah l New Member
    Feb 16, 2018
    Hey I'm new to the mini community just found this forum figured I'd say hello and I had a few questions on how I might make my R53 Type S faster
  2. Qik
    Qik Well-Known Member
    Oct 27, 2015
    1,421
    670
    IT
    Atlanta-ish
    Good morning and welcome to MA!
    There's plenty of R53 owners that have MINI's from slightly modded to completely built and breathing meth. I'm sure they'll be happy to help.
  3. Noah l
    Noah l New Member
    Feb 16, 2018
    Awesome I'm running pretty much bone stock right now I have an air filter and that's about it everything stock I was thinking of putting a bigger pulley on my supercharger
  4. MCS02
    Welcome to MA! Post some pic of that R53.
    I would go with a 15% pulley. when you do that you should go head and install a new tensioner and idler pulley. you will also need the smaller belt for that pulley. Chad at Detroit Tuned is a great guy I get most of my stuff from them. http://www.detroittuned.com
    The Tensioner you can find cheeper on Amazon. Check your crank pulley if the rubber on it is starting to crack get a new one. If it fails it causes badness to happen. I went with a ATI supper damper. It will last forever.
    A nice cat back exhaust would be next. Those mods are the best bang for the buck.
    Check your front control arm bushings if the car has more than 30 or 40k on it they are bad. kick the front of the front tire. If it moves back its bad. Replace them with PowerFlex bushings. they will last the life of the car.
  5. Noah l
    Noah l New Member
    Feb 16, 2018
    Thankyou mc.. my bushings are bad yes it's got 170k on it so it's getting up there in mileage . I'm replacing them next week along with my stock suspension I'm getting coilovers
  6. MCS02
    These are the best coil overs. Colin is good to work with and knows how to build what will fit your need. I have them on my R58.
    https://www.greeneperformance.com/collections/mini-oem-performance-parts/products/bc-racing-coilovers-with-swift-springs-and-custom-revalve
    Detroit Tuned sales the PowerFlex for a few years now you will like them.
  7. Qik
    Oct 27, 2015
    1,421
    670
    IT
    Atlanta-ish
    Post some pictures of your MINI!
  8. Sully
    Sully Administrator
    Jul 21, 2015
    2,100
    916
    Software
    30350
    Welcom to MA - can’t wait to see if your going “mild” or “wild” with the tuning. A forum you will want to visit is the Technical Q&A lots of good information there. In that forum their is a category for 1st Generation MINI and a tuning section.. good reading while you poking around.
    Here is the direct link: https://www.motoringalliance.com/forums/technical-question-and-answers.555/
  9. fishmonger
    fishmonger Well-Known Member
    May 13, 2015
    984
    769
    Madison, WI
    there is a lot of stuff you can spend coin on to make the Mini faster. First you have to ask yourself what faster is for you: curves, straight line, or just looking faster (the trend with current Minis - add lots of red paint and carbon fiber bits and who needs a new cylinder head?)
    My list of what makes a car faster in the corners, top to bottom in diminishing importance
    a) sticky summer performance tires - don't bother doing anything else unless you have this one checked.
    b) rear anti roll bar upgrade
    c) replace all suspension bushings and ball joints
    d) lower car with quality coilovers, add to that lower control arms in back, as well as shorter downlinks
    e) reduce unsprung weight on all corners - i.e. spend coin on ultra light sub 16 lbs wheels
    f) remove weight from the car overall - i.e. ditch rear seat, justify aftermarket exhaust, justify aftermarket brakes with aluminum mounting hats (helps with step e as well)
    g) add some braces where they may help the car - mostly added weight and placebo effect, but a welded roll bar will stiffen things up real nicely.
    My list of what makes the R53 go faster in a straight line is a lot shorter, because I feel the car has plenty of pep even if you keep these things close to stock
    a) 15 or 17% pulley. I have cars with both and must say in daily driving I highly prefer how the 17% comes on. obviously new spark plugs and belt go along with this upgrade.
    b) Milltek cat-back exhaust (or Megan Racing if lower quality and louder noise are ok)
    c) DDM Works cold air intake. Even if there's not much extra power, the sound track inside the car changes dramatically and you will feel like Carol Shelby just tuned your engine
    d) Detroit Tuned bypass valve (for more pickup and better throttle response around 3000rpm)
    Other worth while updates/fixes/maintenance
    a) engine mounts. Replace with new, immediately, or get aftermarket for all three if you have $800 burning a hole in your pocket. Makes shifting smoother, reduces vibrations, just better.
    b) ATI engine damper, new idler pulley, new belt tensioner. All worth while doing while you are putting that 15/17% pulley on the supercharger
    c) stainless steel braised brake lines
    d) Royal Purple SynchroMax oil in the 6 speed and thoroughly spray the shifter linkage with some teflon dry lube - shifting will be so much smoother.
    • Like Like x 2
    • Informative Informative x 1
  10. Sully
    Sully Administrator
    Jul 21, 2015
    2,100
    916
    Software
    30350
    Good starting guide! :)
  11. Dave.0
    Just buy a big RMW 1.8 stroker motor. (( Kidding ))
    All the list will give you a nice boost in power. Just remember what goes faster must also stop better. Brakes upgrades are a good investment.
    Also make sure you upgrade or replace suspect OEM maintenance parts. Pullies, belots, fluids, bushings and so on.
    When you are all done your upgrades you can get your car custom tuned on a dyno. Most people that want 250 hp at the wheels get a larger injectors, Cam and a big valve head.
  12. MCS02
    As you can see there are some R53 fanatics here. One no one said is Chili Red........Chili Red is the fastest color!:D:Stig:
  13. Sully
    Sully Administrator
    Jul 21, 2015
    2,100
    916
    Software
    30350
    There are a number of good how to article you may want to look at.. including one for replacing the suspension. Here is a link:
    https://www.motoringalliance.com/articles/category/1st-generation-mini.6/?full=1
  14. Goldsmithy
    Jan 30, 2015
    1,748
    982
    TCB
    Main Street in the land of Oz
    Welcome to the modness... This is a great site and greater people. The first thing to do before any mod's is to make sure your engine is up to snuff. A compression and leak down test would be in order before you sink any money into a bunch of mods. And then go as wild as you like...we're here to answer questions and spend your money :)
