R53 top engine mount stabilizer thingy
Discussion in 'Want to Buy' started by RallyMini370, Apr 3, 2014.
  1. RallyMini370
    I need a top engine mount extension bar thingy that bolts to the inner fender? Not the lower barral part but the craddle that bolts to the cylinder head and bar and bracket that goes to the fender to stop the engine rocking and rolling.
    Those things suck ^^ they come apart over time. I have had two so I know what I am talking about.
    Chris, can you post us a picture of the part you need. I am sure one of us can find it for you.
  3. clifforddward
    clifforddward Active Member
    Dec 2, 2013
    104
    76
    Cary, North Carolina
    Doesn't the Vibra-technics RH Upper engine mount pretty much take care of this issue, making this rigid device redundant and eliminating any advantage it might provide?
  4. RallyMini370
    Yes RKW like that but I have to use the original. like the one here which should be up to the job as I'm using a weedy R50..LOL I have solid race inserts on the other mounts but I still get a little bit of rock and roll.
  5. clifforddward
    Dec 2, 2013
    104
    76
    I think there is a track version of the Vibra-Technic mount that would provide the extra stiffness you may desire.
    Dave, I just installed my Vibra-Technics mounts so cannot provide much perspective...but haven't you had a set installed on your Mini for some time?
  6. Dave.0
    Here you go Chris.
    Give Colin a call and he can get you one in the race version.
    https://www.greeneperformance.com/mini/mounts/minuprr53erly.html
    Upper engine mount for early R53 chassis. Similar to the Late style mount but shorter. Made for the early style motor mounts on the R53. Please call or Email if you are unsure what part you need. Made from T6 CNC cut Aluminum with natural rubber Insulator. This mount will provide you the best vibration damping and engine control.
  7. RallyMini370
    Thanks Dave but the problem is the rally rules say I have to use original parts. A nice post CNC bar would stand out like a sore thumb. That's why I use a S oil cooler.
  8. Dave.0
    That's what spray paint and dirt is for. :ihih: Don't put it in and have it look car show clean. :Thumbsup:
  9. RallyMini370
    Plus.....I'm cheap so used stabilizer would be great.....free even better! I saw one on Ebay but some bits were missing. I figure someone must have one rusting in their garage.
  10. rkw
    rkw Well-Known Member
    443
  11. RallyMini370
    Bingo! I need 1,6,8 and all the bolts. On Ebay they just have 1 which bolts to the head and it's in the UK. Still looking.
    Thanks for the link.
  12. rkw
    443
    Enter each part number you want into Google and eBay.
    RealOEM.com * BMW R50 Cooper Engine Suspension
    Vendors or dealers seem to have all items available on new parts catalogs (or just look on ecstuning). You'll have to shop around for used.
  13. ScottinBend
    Do you have stiffer bushings in the bottom engine mount/torque bar? This is where most of the engine stiffness can be increased.
  14. RallyMini370
    Yes, the bottom mount and the gearbox mount have the race type poly inserts but the top right side is the original mount with rubber donnut sat on top . So maybe fitting the S stabilizer bar is a waste of $$$?
  15. clifforddward
    Dec 2, 2013
    104
    76
    Chris:
    Sorry, when I provided my Vibra-Technics suggestion I did not realize you were dealing with particular Rally rules limiting options to OEM parts....hopefully you can find the parts you need to stiffen up all of your engine mounts.
  16. Dave.0
    Remember it's not cheating unless you get caught, just like speeding. :ihih::devil:
  17. RallyMini370
    No worries Cliff I've found all the parts on Ebay for $65 shipped.
  18. rkw
    443
    Just don't win or place. Or better yet, DNF and nobody will even care.
