If you are in SoCal and need a carbon clean on your R56, October is your month! Through the end of October Motoring Magic will offer a walnut shell blast of the intake valves on R56 engines with a 95.00 discount! Normal price for this service is 445.00, call now for your appointment. We use an oem blast machine purchased directly from MINI. 805-496-2300 2007-2010 N14 turbo engines suffer from carbon buildup on the intake valves due to a poorly designed crankcase vent system allowing hot oil vapor from the pcv recirculation system to collect on the hot intake valve in the intake ports, causing a large lump of carbon to form. This causes restricted airflow over the valves and hesitation, hard starting as well as lower fuel economy. don't forget we are open saturdays! Motoring Magic 805-496-2300
