Exterior 1st Gen R56 GP2 Rear Diffuser on R53 - DONE...!
Discussion in 'Tuning and Performance' started by PoonRacing, Dec 15, 2014.
  1. PoonRacing
    PoonRacing Member
    May 2, 2011
    Ohio & Hong Kong
    That looks 100% better the Group 4 one, nice work. :Thumbsup:
  3. Metalman
  4. MCS02
  5. Firebro17
    Very nice addition.
  6. Nathan
    Look great.
  7. cct1
    That does look good. If you're doing it for looks, great job. If you're doing it for function, definitely do the underpanels, otherwise it's mammary glands on bull.
  8. rum4
    rum4 Club Coordinator
    4,568
    1,475
    SC
    Looking good
  9. Sleek Motoring
    Sleek Motoring Local Shop Owner
    Dec 7, 2014
    249
    143
    Mini repair shop owner
    Colorado Springs, Colorado
    Awesome looking setup!
    Not to hijack your thread...But here goes:biggrin5:
    How would one add under panels if you have Chassis bracing?
  10. GokartPilot
    GokartPilot Well-Known Member
    Jan 9, 2012
    967
    727
    training specialist
    Maysville, North Carolina USA
    Very nice, one of the main things IMO that the GP1s are missing. If you don’t mind me asking what was all the cutting and welding happening to besides the exhaust?
  11. PoonRacing
    PoonRacing Member
    May 2, 2011
    Ohio & Hong Kong
    Thanks guys it's just for look, someone challenge me that no way will fit on R53 so I did it to prove it's possible :biggrin5:
    you got to cut out the battery box to made room for the new exhaust, the center air duct trim locking tap all need to be cut out and shorten because none of it line up with the r53 bumper cover, I made that 3 custom hold down (see the pics from flickr) to lock it in place. both left/right air duct also need to cut to fit around the lower control arms and more custom bracket to hold it up (I didn't buy the bracket that came with the kits)
  12. cct1
    Take the bracing off put the panels on, done. The panels use preexisting holes (depending on the bracing they may share a couple of attachment points), they need to be trimmed toward the engine bay to fit the R53, other than that it's a pretty simple job.
  13. Sleek Motoring
    Dec 7, 2014
    249
    143
    So what you're saying is; its either one or the other? It seems as though putting the bracing on top of the paneling would pretty much defeat the purpose of it in the first place!
  14. Dave.0
    I would take bracing over plastic panels only because a MINI's speed is made in the corners not the straights. :ihih:
  15. GokartPilot
    Jan 9, 2012
    967
    727
    training specialist
    Sorry about that, I missed the flickr link. The pics are great and will give me something to show my body guy when this mode comes up. Again very nice mod! :Thumbsup:
  16. cct1
    No, it'll still smooth out airflow--lots of nooks and crannies for air to get sucked into. Yes, the bracing will make it less effective, but it'll still smooth out what goes underneath.
  17. Spa2k
    Spa2k Well-Known Member
    May 9, 2013
    1,955
    975
    Iowa
    And the under-engine panel keeps stuff from splashing up into the engine compartment. Mine still looks essentially like it did when I took delivery of the car.
  18. TheModFather
    Mine does not! :p
  19. cct1
    Well, you kinda sorta have to have an engine in the engine bay to qualify on this one...
  20. Metalman
    It also helps the cooling system by creating a vacuum assist behind the radiator...
    Here is a pic of mine when I did the install...
