2nd Gen "How To" R56 Manual Transmission Fluid Change
By Qik · Mar 20, 2018 ·
  1. Qik
    Qik Well-Known Member
    Oct 27, 2015
    1,421
    670
    IT
    Atlanta-ish
    Qik submitted a new Article:
    Read more about this article here...
  2. Qik
    Oct 27, 2015
    1,421
    670
    IT
    Atlanta-ish
    I just did this tonight! I'd like to add onto the How-To. I'd recommend getting an extra long hose to run from your bottle pump to the fill hole and secure tubing to the exhaust using a zip-tie so you don't need to hold it. Lower the car so she's level, lay down and watch for the overflow to run out. I found that if I leave the car jacked up on the passenger side it takes about a half qt extra that ends up being spilled into your drain pan once you lower it to let the over flow drain out. Fyi.
  3. Sully
    Sully Administrator
    Jul 21, 2015
    2,100
    915
    Software
    30350
    Good info - thanks for the update. :D
  4. Dave.0
    Having a buddy with a shop and 7 lifts helps also.
  5. Sully
    Sully Administrator
    Jul 21, 2015
    2,100
    915
    Software
    30350
    Man its soo nice when working on a lift. So nice.
