2nd Gen R56 Cooper S R56 MCS sport suspension vs standard suspension
Discussion in '2nd Generation: 2007+ R55 through R61' started by Jason Montague, Jan 10, 2010.
  1. Jason Montague
    :mad2: Mini Margi is an 08 MCS JCW(Dealer kit) R56 that has a sport suspension (not sport package but sport suspension) listed as such on the window sticker with all the other options. Trying to find out which componants are different and how they are different(specifications of both) has been like trying to find out your girl friends age and weight. Mini USA states that the springs are heavier(no mention of ft/lbs thankyou very much)and they lower the car by 8mm over stock. They state that the shocks(dampers) are heavier also. What the heck does that mean? There's no mention of the difference in compression damping or rebound between stock and sport suspension. There's also no mention of antisway bars. I've measured the rear bar's circumference and dividing by 3.14 get 22.something;so it appears that the rear antisway bar is heavier. Does anyone (Dr Richter,Nathan,TSW,others)know which componants are different and what the specs are on standard and sport parts? The car handles better than I can drive her but I'd like to know the differences.:confused5: Thankyou Jason
  2. Rixter
    Rixter Well-Known Member
    Jun 14, 2009
    1,230
    79
    Technology Architect
    North of the 49th
    I have the same on my '08 MCS. I can't speak to the specifics, except to say that the rear antisway bars are 18.5mm which is the same model as on the JCW
  3. lhwelch
    lhwelch New Member
    Oct 1, 2009
    Check out realOEM.com. The standard antisway bars listed there are 22 mm front and 17 rear. The JCW bars are listed as 24 front and 18.5 rear. Unfortunately the spring specs are not shown.
  4. Metalman
    The springs are sized based on the options that came with your MINI (weight).
  5. Jason Montague
    Standard vs Sport Suspension
    :D Thanky'all very much. Every little bit helps and now I know that I just may have erred in measuring the rear sway bar. This is a very friendly and helpful site. I've got several posts and haven't been told that I'm an idiot yet.(okay I've set y'all up. You can call me an idiot now.:lol:) Jason
  6. lotsie
    stagehand/part time detailer
    Right here
    Jason, we don't call each other idiots on this site. Goofs maybe, but not idiot:Thumbsup:
    Mark
  7. rkw
    rkw Well-Known Member
    443
    Where did you see that? Sport suspension is the same height as standard suspension. The JCW suspension (dealer installed, purchased separately) is about 1/4" lower.
    Sport suspension has different springs, shocks, and both sway bars. JCW suspension includes yet another different set of all those components.
  8. rkw
    443
    BTW, just making sure there isn't confusion about it... the dealer JCW (engine) kit doesn't include JCW suspension.
  9. Jason Montague
    :DThankyou Jason:Thumbsup:
    :DThankyou and yes I do know that my JCW is only: air intake, exhaust ,and ECU upgrades. Thankyou Jason :Thumbsup: P.S. I appologize for getting my messages mixed up with y'all's. I plead computer ignorance. Jason :Thumbsup:
  10. rkw
    443
    No, that's not correct. There are 3 suspensions offered by MINI:
    1. Factory standard suspension
    2. Factory sport suspension (struts, springs, sway bars stiffer then standard)
    3. Dealer installed JCW suspension (struts, springs, sway bars even stiffer than factory sport suspension)
  11. Redbeard
    1,636
    398
    Glorified spreadsheet jockey.
    Okay this has me interested. I picked the Sport Suspension option with mine and I am curious to know the actual ratings on the suspsension.
    When I test drove one with and one without I could feel the difference in stiffness and it seemed like the sport had better turn-in though I am far from an expert there.
  12. Rixter
    Jun 14, 2009
    1,230
    79
    North of the 49th
    #12 Rixter, Jan 11, 2010
    I thot there was also a 4th and that's the JCW Sport Suspension (for $1K + installation)
  13. andyroo
    andyroo New Member
    227
    6
    Columbia, MD
    the only thing i would really want from the kit is the rear swaybar.
    just my opinion. :)
  14. rkw
    443
    There is only one JCW suspension. Sometimes "Sport" is used in the name, sometimes not, but it refers to the same thing.
  15. Jason Montague
    Sport vs Standard Suspension
    Okay guys here's the latest word from the parts dept @ Mini of Dallas. Standard Susp-front sway 22.5mm,rear sway 17mm, standard struts Sport Susp-front sway 23.5mm,rear sway18mm, front and rear struts heavier and different part # from standard JCW Susp-front sway 24mm, rear sway 18.5mm,struts marked JCW and heavier than sport and have extra strut bump stops :Thumbsup: I think that this all the info that we'll be able to get from MINI. Jason
  16. Nathan
    Front Rear Strut Type
    Standard 22.5mm 17mm Standard
    Sport 23.5mm 18mm Sport Specific
    JSW 24mm 18.55mm JCW Specific
    Source - MINI of Dallas Parts Dept.
  17. Rixter
    Jun 14, 2009
    1,230
    79
    North of the 49th
    #17 Rixter, Jan 11, 2010
    But I believe there's the stock JCW suspension and then there's the upgraded Sport suspension for about $1K (excluding installation) (Morristown MINI)
    According to RealOEM, here's the parts for the JWC suspension http://www.realoem.com/bmw/partgrp.do?model=MF93&mospid=50964&hg=31&fg=10 and then here's the parts for the JCW Sport suspension http://www.realoem.com/bmw/showparts.do?model=MF93&mospid=50964&btnr=31_0806&hg=31&fg=95. The struts are listed as seperate parts
  18. rkw
    443
    #18 rkw, Jan 11, 2010
    The dealer-installed item called "JCW Sport suspension" on the RealOEM and Morristown MINI sites is the only "JCW" suspension available.
    A factory JCW S is fitted with the exactly same suspension as a regular S (either standard or sports suspension).You're just misunderstanding the title at the top of the RealOEM page. It says "R56 Coop.S JCW" because that's the model you selected. It will say that on the top of every page. Compare the actual part numbers between a
    regular R56 S: RealOEM.com BMW R56 Cooper S Stabilizer, front
    R56 JCW S: RealOEM.com BMW R56 Coop.S JCW Stabilizer, front
  19. Redbeard
    1,636
    398
    Another newb question: I'm seeing strut info and sway-bar info. Does that mean the spring rates are the same?
    Part 2 of the Newb question: Are the sport springs a progressive rate or linear?
    *zips up newbie flame suit*
  20. andyroo
    andyroo New Member
    227
    6
    Columbia, MD
    Whether the sprigns are progressive or linear is a moot point, since you will be using the progressive foam bumpstops as part of your spring rate essentially 100% of the time.
    - andrew
