2nd Gen R56 Cooper S R56 mechanical boost gauge location
Discussion in '2nd Generation: 2007+ R55 through R61' started by Guapish_Fliver, Jan 4, 2017.
  1. Guapish_Fliver
    Guapish_Fliver New Member
    May 31, 2016
    272
    Pimpin
    Da wess
    I thought I'd share some pics on how to install boost gauge without any special mounting hardware since I didn't see this setup anywhere else. I gave up on the vent idea and did this instead. Only minor hacking involved.
  2. Guapish_Fliver
    May 31, 2016
    272
    Pimpin
    Da wess
    I can only do 1 pic at a time
  3. Guapish_Fliver
    May 31, 2016
    272
    Pimpin
    Da wess
    Third pic
  4. Guapish_Fliver
    May 31, 2016
    272
    Pimpin
    Da wess
    Last 1
  5. Dave.0
    Nice job
  6. Metalman
    Almost the same exact location I went with.
    I came up with a bracket that uses the screws on the back of the tach....
    Also added a programmable shift light above my boost gauge.
  7. Guapish_Fliver
    May 31, 2016
    272
    Pimpin
    Da wess
    Noice. Is that one electronical? I can't see your tube out the back.
  8. Metalman
    Mechanical... Routed behind the steering column cladding through the firewall. Wrapped the tube with black mesh wire sleeving that matched the OEM wire wrap...
    This stuff...
  9. 00Mini
    2,227
    Good job. :Thumbsup:
  10. DneprDave
    Could you make your pictures a little smaller?
  11. Guapish_Fliver
    May 31, 2016
    272
    Pimpin
    Da wess
    How much vacuum is normal at idle?
  12. MCS02
    Looks good! I wish I had a Mini........oh wait I do it's just not running.
  13. MCS02
    The normal amount!:biggrin5:
  14. Guapish_Fliver
    May 31, 2016
    272
    Pimpin
    Da wess
    My car sits at 16-20 hg at idle. Seems pretty high but idk.
  15. oldbrokenwind
    oldbrokenwind Active Member
    Oct 18, 2012
    196
    107
    Northern NV
    That's about what mine was running before it blew. 'Course I'm at 4500' but that shouldn't make any difference.
    Did you ever get your tuning problems solved? Haven't seen any updates to your tuning thread.
  16. Guapish_Fliver
    May 31, 2016
    272
    Pimpin
    Da wess
    #16 Guapish_Fliver, Jan 7, 2017
    Yeah I haven't had the car back long enough to do any legitimate updates, I got burnt out and was busy with the race season over the summer so I dropped it off and told Jzw to take his sweet time with it. I've just now finally started messing with it again. Jzw treated me right and it's got a few maps now with an ethanol 100 octane option. It had a few miracle pulls before things come apart. I'll post a dyno in a few weeks.
    Haven't seen you in a while obw! Glad you came back so I can give you hell about that pos boost gauge adaptor u sold me. It looked like a sad attempt at a custom fabrication job in ur garage.. It had to be destroyed like a noxious weed so that no one else can be exposed to that "gem" in the future. lmao.. No hard feelings but I have to give you a hard time about that one. :lol:
  17. 09PepperWhite
    09PepperWhite Active Member
    May 3, 2015
    136
    100
    Donation funds allocator non profit organizations
    United States of America & Texas is a Great State
    If this helps to add to the information? My 2009 MCS idles @ -6.87 to -8.5 psi @190F
    so 14-17hg
    Slightly higher idle reading 17.5-18.5hg @224F and depending on the outside temperature.
