2nd Gen R56 Cooper S Radio feedback when using iPhone 4
Discussion in '2nd Generation: 2007+ R55 through R61' started by Thunderball Kaboom, Dec 28, 2010.
  1. Thunderball Kaboom
    Thunderball Kaboom New Member
    Aug 17, 2010
    49
    I am the Coordinator for a program that provides h
    Live and play in Central Phoenix - Camelback corri
    I have a 2007 MCS with the Hi Fi radio. I use the aux port to listen to music from my iPhone, and have noticed hissing and distortion after upgrading to an iPhone 4. My partner's iPhone 4 creates the same feedback. I'm not getting feedback when using an iPod, so it doesn't appear to be the cable or port. Has anyone had a similar experience, and were you able to eliminate the feedback?
  2. BThayer23
    #2 BThayer23, Dec 28, 2010
    Sounds like you need a ground loop isolator. Basically the iPhone and the car stereo are powered by two different power sources (battery and alternator), and if there's a slight difference in ground voltage, you'll get some hiss. I have a Kensington car charger & aux input cable that's a few years old and works great. You'll get better sound quality if you use the line out from the big Apple connector instead of the headphone jack, too.
    [ame="http://www.amazon.com/Kensington-Charger-Audio-Cable-iPhone/dp/B0031U1AU0"]Amazon.com: Kensington 2-in-1 Charger and Audio Cable for iPhone/iPod: Electronics@@AMEPARAM@@http://ecx.images-amazon.com/images/I/31reMtk4ULL.@@AMEPARAM@@31reMtk4ULL[/ame]
    Or they just sell an aux input cable with a GLI.
    [ame="http://www.amazon.com/Kensington-Noise-Reducing-Audio-SmartPhone/dp/B0031U1ATQ/"]Amazon.com: Kensington Noise Reducing Car Audio AUX Cable for MP3 or SmartPhone: Electronics@@AMEPARAM@@http://ecx.images-amazon.com/images/I/31NmPSqeVoL.@@AMEPARAM@@31NmPSqeVoL[/ame]
  3. Thunderball Kaboom
    Aug 17, 2010
    49
    Thanks for the help and the link. My aux port doesn't have the USB connection, so I have to use the headphone port. I don't think I've ever seen a cable for output from the sync port to a non USB aux port.
  4. BThayer23
    Oops, just saw that I posted two of the same link above. Fixed that.
    Yeah, those ipod line out cables aren't marketed much but they're fairly common. The Kensington unit (or others like them) is nice because it integrates the GLI and the cigarette lighter power adapter. If you want to go the cheap route without power, try this:
    [ame="http://www.amazon.com/FiiO-L3-Line-Cable-iPhone/dp/B003UCESP8/"]Amazon.com: FiiO L3 Line Out Dock (LOD) Cable For iPod and iPhone: Electronics@@AMEPARAM@@http://ecx.images-amazon.com/images/I/31YjfE-ncvL.@@AMEPARAM@@31YjfE-ncvL[/ame]
    and this (I have one of these, they work well):
    [ame="http://www.amazon.com/GROUND-LOOP-ISOLATOR-3-5-APPLICATIONS/dp/B001EAQTRI/"]Amazon.com: GROUND LOOP ISOLATOR FOR 3.5 MM APPLICATIONS: Automotive@@AMEPARAM@@http://ecx.images-amazon.com/images/I/31SYqE1VYcL.@@AMEPARAM@@31SYqE1VYcL[/ame]
  5. Thunderball Kaboom
    Aug 17, 2010
    49
    This is awesome info - I'll order now! Thanks so much!
  6. Thunderball Kaboom
    Aug 17, 2010
    49
    Thanks for the help with this issue. I purchased the Kensington cord with the in-line noise suppressor, and it works perfectly! No more hiss.
  7. BThayer23
  8. slimjimtell
    slimjimtell New Member
    Apr 25, 2010
    I ordered the Kensington noise reducing cable. This makes the music sound terrible. It did take out the noise, but now the iPhone sounds like a transistor radio. Terrible solution!
    Anyone know if this is resolved through MINI updates?
    Any other suggestions?
  9. Metalman
    I have an 09, also with the Hi Fi radio. My MINI came with a special "Y" connector cable (it's listed in realoem). It uses the standard 30 point Apple plug and then splits into the USB plug and mini audio plug for the aux plug in the bottom of the center stack. Works like a charm, no hiss or interference. The songs played from my IPhone 4 sound every bit as good as the CD music. Much better than the radio reception.
  10. slimjimtell
    Apr 25, 2010
    I have the same Y cable that came with my 2010. It makes noise, a griffin cable makes noise, just a 3.5 plug from the headphone jack makes noise.
  11. Metalman
    Weird there is such a wide variance in sound quality.
  12. Thunderball Kaboom
    Aug 17, 2010
    49
    Search for Fios iPhone 4 on amazon.com - they now make a 20" long cable for the dock connector port. The sound quality is great.
  13. Nathan
    Did you mean FiiO? Any kind of search of Fios brings up the internet/tv service.
    This what you had in mind?
    [ame="http://www.amazon.com/FiiO-20-Inch-Line-Cable-iPhone/dp/B005DK08X6/ref=pd_cp_e_4"]Amazon.com: FiiO L10 20-Inch Line Out Dock (LOD) Cable For iPod and iPhone: MP3 Players & Accessories@@AMEPARAM@@http://ecx.images-amazon.com/images/I/31Ldhm5ZhsL.@@AMEPARAM@@31Ldhm5ZhsL[/ame]
  14. Thunderball Kaboom
    Aug 17, 2010
    49
    Sorry,yes, that's it. I bought the short connector, and used an extension cable to run from the aux port to the armrest. I tucked the cable under the center console and the armrest had built in channels for the cable. I don't think the 20" inch cable is long enough to do this, but it should give you enough cable to be able to pick up your phone to change songs, etc. sound quality is great, and the cable is inexpensive.
