Brakes Wheels 2nd Gen Tires Rear Brake Grinding
Discussion in '2nd Generation: 2007+ R55 through R61' started by RllyDrvrIX, Jan 19, 2011.
  1. RllyDrvrIX
    RllyDrvrIX New Member
    Oct 22, 2010
    221
    11
    When I leave the car overnight in the (unheated) garage I have a nasty rear brake grind noise leaving for work the next morning.
    It sounds like the rust monster came in and went crazy on my rear rotors. My fronts are fine but not the rears.
    Should I suspect an issue or is this normal?
    Thanks!
  2. minimark
    Sounds like the parking brakes are sticking....
  3. Minidave
    4,592
    Normal.
    My '09 Clubman S makes so much noise as I back out of the driveway, especially if I haven't driven it for a couple of days but within a block or two they're fine....and I know the pads and rotors are fine - so I just don't worry about it.
  4. RllyDrvrIX
    Oct 22, 2010
    221
    11
    Cool, thanks!
    The rotors being raw metal & rust really fast. I get this sometimes & it goes away after a few brake applications.
  6. SooperCooperInfo
    May 31, 2009
    78
    Retired aircraft salesman
    Land of Oz
    Some airplanes I used to fly did the same thing and we called it "morning sickness."
  7. quikmni
    quikmni Moderator
    Jun 6, 2009
    774
    174
    Aerospace Engineer
    Orcutt, CA
    I get the same noise even after I wash the car and let it sit for a few hours before driving. The rotors rust very quick.
  8. minimark
    Ummmm... Mine is garaged but it did do this once and I cleaned and lubed the guide pins and then adjusted the parking brake. Problem gone. 2cents
  9. Redbeard
    1,636
    398
    Glorified spreadsheet jockey.
    I thought that was when you were getting stuck valves from carbon build-up causing the engine to sputter until it came to temp... Usually an early warning sign before in-flight failure. :crazy:
    Back on topic... :ihih:
    I get the "grind" out of the rears in the morning here. Two stop signs later its fine. :Thumbsup:
  10. TGS91
    TGS91 New Member
    May 8, 2009
    1,593
    Sales Dude
    St. Louis, MO
    Mine did the same this AM. I attributed it to salt from the road. Couple miles no prob
  11. Nitrominis
    Nitrominis Banned
    61
    Doing nothing
    Santa Cruz, CA
    Brakes are a part of a car that if you have to ask this question take it to a shop that specializes in brakes. Do not trust (although great answers) forum responses in this matter. You need to have someone qualified examine them for any possible damaged. Your life as well mine could be at stake.
  12. TGS91
    TGS91 New Member
    May 8, 2009
    1,593
    Sales Dude
    St. Louis, MO
    Wise words (once again)
    My situation maybe diff than yours (for example I know I personally inspected the pads for wear less than 60 days ago)
    Take it to the pro's.
    You could offer more data, how old are pads?, when was last time brake fluid flushed? age of rotors?, etc Even then it's a opinion
  13. RllyDrvrIX
    Oct 22, 2010
    221
    11
    2010 w/under 6K miles. After 2 stops (end of driveway and first stop sign) the grinding is gone. I looked this morning and saw oxidation on the braking surfaces of the rotor.
  14. RllyDrvrIX
    Oct 22, 2010
    221
    11
    It's been a couple months but used an oil change and winter tire swap to have a MINI mechanic take a look and brakes are all good. It's rust build-up while the car sits....
    Thanks for the heads up. We knew that. ;)
  16. iwashmycar
    iwashmycar Active Member
    Jun 1, 2009
    881
    87
    architecture
    Mine make a whirring sound that I can hear while slowly driving out of my apt complex. I think it goes away eventually but I usually attribute it to the parking brake dragging some. I also have 50k miles and there are some pretty good "lips" on the very edges of the disks where the pad doesn't hit. Wonder if I should file them off?
  17. Crashton
    I probably wouldn't bother doing that. Are you still on the oem pads? If so you have to be close to new brake pad & rotor time.
    My brakes make a whirring that I attribute to my slotted rotors.
  18. old81
    1,542
    Hey I can do a car wash, wipe down then let the car sit for 4 hours on the CM or the 07 MCS and get grind.
    MINI pads attract sticky rust. Just go out and drive them hard. :D
  19. iwashmycar
    Jun 1, 2009
    881
    87
    architecture
    All stock. Was a lot of highway in the beginning though.
    Ill be looking into new ones mid summer I'm sure.
    You can borrow my mystery brake wonder tool when the time comes.
    Just replaced rear pads this week on good ol BLU BRIT...
