Rear brake pad advice
Discussion in 'Track Days & HPDE's' started by btwdriver, Aug 17, 2009.
  1. btwdriver
    btwdriver New Member
    I am looking for a rear brake pad for the track. I am currently running the TSW BDM kit in the front with some Raybestos ST-43 pads. The Raybestos pads have a fairly high coefficient of friction. I am looking for a set of brake pads for the rear that will give me a proper brake bias with the front pads.
    I am currently running the Carbotech XP8's on the rear, and I feel as if they aren't aggressive enough for the Raybestos pads. TSW recommended some Porterfield R-4's for the rear, but it looks like they don't make them for the R56 yet.
    Thanks!
    I was going to mention the Porterfield R4 as I've been using them for both track and street and am rather happy with the performance. But, since they are not yet available in you application...
    I got nothing.
  3. BThayer23
    I was thinking about running that ST-43 / XP-8 combo next month... you didn't like it?
  4. btwdriver
    It's not that I hated it. I have been having some brake overheating issues and think at least some of it might be attributed to the rear pads. The ST-43's are a pretty aggressive front pad, and my thought is that the XP-8 is not as aggressive. If I am thinking about this correctly, when you apply the brakes the ST-43's have a larger coefficient of friction causing them to do a disproportionally larger amount of braking than the XP-8's.
    Some of this is pure conjecture and some is based off the wear that I am seeing on my rear pads. I know rear pads don't really wear that much, but I have run more than 8 DE's, plus all my street driving on the rear pads, and they still look brand new.
    In a shotgun approach to alleviate the boiling of brake fluid, this is one of the steps I am trying to eliminate as a possible issue. Dr. Mike and many others are running the TSW BDM ST-43/R4 combo and seem very happy with it.
    On a side note, I just called PorterField and they indicated that they do make the R4 for the R56. They just don't have it listed on their site. I will post back once I actually have them in hand and verify they fit.
  5. Alan
    Alan Active Member
    98
    New Braunfels, Texas
    I had been running EBC Yellows, but had bad inner pad wear with the last set. I think they screwed up when boxing up the set of pads. This never happened before and I've been through at least a half dozen sets. I was getting about 8 DE weekends.
    I have a set of Porterfield R4 on the rears now, and a set of HP+ in the track box to try after that.
    Alan
  6. Sneedspeed
    Sneedspeed New Member
    Jul 16, 2009
    165
    56
    Racing cars
    Pfafftown NC
    Remember the brakes should work 70% on the front 30% on the back. I split my pads one heat range front to rear. XP12s in the front XP10 in the back. On the E30s we split 2 ranges because the rear rotors dont get hot enough. Track pads dont "work" untill they are up to temp. If your not smearing your pads on the rear you may want to try going down a heat range to an AX6. This will put the rotor/pad more in the correct temp range for your driving and give more bite on the rear.
  7. Sneedspeed
    Jul 16, 2009
    165
    56
    Racing cars
    Pfafftown NC
    Also brake temps change with air temp too. You may need to change heat ranges for winter track days because the rotors dont stay as hot as long in the cold weather.
  8. beaner
    beaner New Member
    44
    i agree that the front brakes are doing most of the work. i have also discovered, however, that my rear brakes get hotter than my fronts. i run a TCE/willwood 13" front rotor w/ poly h pads, TCE rear rotors w/ R4 pads. solid vs. vented rotors are the culprit, i believe. i might go to a vented rear rotor on the racecar.
