1st Gen R53 Cooper S Rear Chassis Brace
Discussion in '1st Generation: 2002–06 R50, R53 & 2004–08 R52' started by wzabrouski, Jun 2, 2010.
  1. wzabrouski
    wzabrouski Active Member
    32
    Executive Director
    Keller, TX
    Is my Mini benefiting from my m7 rear chassis brace? It is limiting me from putting almost anything in my trunk. Are there benefits? I have read that many people don't feel there is a benefit to a rear stress bar. Any input?
  2. Eric@Helix
    Eric@Helix New Member
    1,257
    Shepherd
    Philadelphia
    What is it connecting? MINIs are very stiff from the factory and generally don't suffer from enough body flex to compromise handling. The limiting factor in a MINI's handling is almost always behind the wheel.
  3. ScottinBend
    Rear bar does nothing as it doesn't even connect at the suspension points.
  4. Metalman
    Ahhh.... It sounds like M7 is benefiting from your rear chassis brace:D
  5. wzabrouski
    32
    Executive Director
    Keller, TX
    That is what I thought.
  6. Metalman
    Pull it off and sell it on the sewing site.
  7. Metalman
    I don't mean to hijack your thread, but does the front upper strut brace do anything? They seem to be prevalent in pic's of members engine bays.
  8. Nitrominis
    Nitrominis Banned
    61
    Doing nothing
    Santa Cruz, CA
    Any suspension or body stiffener claimed to do improvement can not always be felt. The use of monitoring device such as a gauge like a Auto Meter D-Pic that can measure lateral and forward G-Forces is needed to see if any effective changes occurred. It is easy to do a before and after using such a devise. So I would not always rule out what you can not feel.
    To be clear I was not insinuating that any particular part did in fact work or did not. Just an easy way to test it.
  9. phydeaux
    phydeaux New Member
    Maple Valley, WA
    I feel that the strut tower brace does provide a significant benefit. I've not been able to explain it, but I noticed immediately that starting out from a stop light, I was able to start smoother and shift smoother. No changes in driving style, but my shifting from 1st to 2nd could be pretty hard sometimes. The STB seems to have smoothed that out almost completely.
    Just my two cents on that one. ;)
  10. Jason Montague
    Front Strut Tower Brace AND Rear Frame Brace
    :Thumbsup: FOR WHAT IT'S WORTH(probably nothing as it's just me and completely subjective) Margi has both front JCW strut tower brace and rear 'chassis brace.'With both of them installed I noticed a definite improvement in cornering. I have nothing to back this up and many knowledgable people say that this is merely excessive operator head space:crazy: but, mine are staying on the car.:Thumbsup: Jason
  11. BThayer23
    The front strut brace definitely made turn in crisper. The front end is a little bit more predictable over street bumps, too (though camber plates helped the most there).
  12. ScottinBend
    If you ask the guys that have tested these you will find out that there is very little these will do to improve the handling (this from an ex-strut brace owner). But they sure do look good under the hood.
  13. BThayer23
    Oh yeah, wasn't there a big thread about that on the sewing site a while back? I think the conclusion was that the lower chassis braces had a bigger effect. But you can't forget about the annoying need to remove the upper strut brace whenever you have to change your oil or service the air filter. :idea:
  14. ScottinBend
    Yep, the lower brace added quite a bit of performance. Not so much for the top one....lol
  15. Jason Montague
    :Thumbsup: I have an R56 with a CAI so I don't have to remove the front strut tower brace to do either of these.:cornut: Jason
  16. orangecrush
    orangecrush New Member
    May 13, 2009
    137
    Not if you have one of these....
    :D
    Mark
  17. Metalman
    Very nice!
    Hmmmmm...... I might have to make me one of those.:arf:
