1st Gen R53 Cooper S Rear Seat Delete
Discussion in '1st Generation: 2002–06 R50, R53 & 2004–08 R52' started by M^Cubed, Apr 26, 2010.
  1. M^Cubed
    M^Cubed Member
    May 24, 2009
    315
    12
    Can I just trace the lower seat cushion? It seems like the easiest way to go about it.
  2. Nitrominis
    Nitrominis Banned
    61
    Doing nothing
    Santa Cruz, CA
    #2 Nitrominis, Apr 26, 2010
    I think the cushion might not have the correct pattern? When I did one with wood I had to make a pattern using paper bags.
  3. k-huevo
    k-huevo Club Coordinator
    159
    Pipe Creek, Texas
    The approach depends on whether it is going to be a hard shelf or soft cover. For a hard cover, remove the seat backs and make a cardboard template at the same height as the intended shelf (the outline will be different than seat cushion or seat back). For a soft cover like carpeting, use wide wrapping paper to trace the template and add .5 inch to the outer edges so it can be tucked under the trim.
  4. M^Cubed
    M^Cubed Member
    May 24, 2009
    315
    12
    It is 1/2" MDF, I will just trace it out. I have the plastic trim on the side out, I might use them as a template.
  5. Nitrominis
    Nitrominis Banned
    61
    Doing nothing
    Santa Cruz, CA
    Hey post some progress pictures I am sure others would like to duplicate what you are doing. :Thumbsup:
  6. M^Cubed
    M^Cubed Member
    May 24, 2009
    315
    12
    HA HA HA! Well... I'm so good with a camera... that part might not even come out either
