Suspension Brakes 1st Gen Rear Sway Bar Adjustment
Discussion in 'Tuning and Performance' started by UKXPAT, Oct 5, 2010.
  1. UKXPAT
    UKXPAT New Member
    Nov 12, 2009
    143
    Crystal Lake, IL
    I can't remember how to change the settings on my rear sway bar. :mad2: Which way do I move the drop link to stiffen up the setting?
  2. Jan
    Jan Well-Known Member
    377
    382
    move it inboard or to the left in that picture
  3. Onasled Racing
    Onasled Racing New Member
    Jul 19, 2010
    172
    Just remember that you only need to adjust one side at a time. No need for both sides to be changed as you are actually skipping a rate if you do so.
    Just putting it out there. ;)
    I never knew that.
    However, when I think about this addled brain says whoa! Would that create an unbalanced Left to Right situation?
  5. Metalman
    Hmmmm......
    Moving to a different hole changes the length of the lever arm.
    It's OK to have mismatched lever arms? I didn't know that?
  6. Onasled Racing
    Jul 19, 2010
    172
    No Nathan. If the bar rotates, as it does, each wheel's movement is distributed throughout 100% of the bar. Yea, hard to explain. Haa
    There are many out there with driver adjustable bars that use the flexible blades just on one side, while the other side is just a solid bar.
    A three hole ajustable bar has six different rates to adjust too
  7. Metalman
    So a 2 hole adjustment bar really has 3 settings? And the sway bar just averages the settings. I just learned something new today.
  8. Onasled Racing
    Jul 19, 2010
    172
  9. ZippyNH
    :beer
    That tip is good enough for a beer!! I think lots of us around here owe you one!!
