Exterior 2nd Gen Removing OEM Bonnet Stripes
Discussion in 'Tuning and Performance' started by MiniJimi, Sep 28, 2011.
  1. MiniJimi
    MiniJimi New Member
    Jul 20, 2009
    35
    6
    West Virginia
    Any tips or advice on removing my bonnet stripes? How do I go about it?
  2. Metalman
    Mine was a 2009, I used a small plastic scraper I got from a friend (a plastic credit card might work). It was used to lift the edge of the stripe to get it started. Now, when I did mine it was much warmer out. If you have a garage , take the MINI out and warm it up if the hood is cold. Then bring it back in the garage, get the edge started (I started up by the wipers) and then started pulling the stripe off pulling towards the bumper. If the tape gets cold, it'll start giving you problems, the adhesive should be warm. If you need to, add some heat with a hair dryer. It ended up being fairly easy. The tape didn't even tear, it pulled off in one fell swoop....:D
    Ahhh, if you use the hair dryer, don't add too much heat, you don't want to damage the paint or blister the vinyl stripes.
  3. MiniJimi
    MiniJimi New Member
    Jul 20, 2009
    35
    6
    West Virginia
    Thanks! I'll give that a try.
  4. Gutterman
    Gutterman Member
    Apr 24, 2011
    Why are you removing them ?
  5. Ernesto
    Ernesto Club Coordinator
    May 16, 2009
    642
    652
    Oracle DBA
    Skokie Ill
    When I removed my aftermarket stripes after 7 years, it left quite a bit of residue..
    I used goo-gone and lots of elbow grease followed by clay bar before putting the new stripes back on.
    I heard later that 3M Adhesive remover is the stuff to use..
  6. Friskie
    Friskie Well-Known Member
    Jul 20, 2009
    1,650
    1,333
    Highly motivated retiree
    In the here and now, for now.
    Hair dryer.
  7. N2MINI
    N2MINI MINI of the Month
    Dec 4, 2009
    3,349
    575
    Sign Maker
    Lighter Fluid works well, as does gas. Just don't be smoking as your doing it!!!!
  8. Firebro17
    Heat Gun...
  9. ScottinBend
    WD 40 is also great for any residue.
  10. Metalman
    Ernesto
    Pretty cool "Ghost Stripes"..... You were way ahead of everyone else in the "Styling Department"....:D
  11. Ernesto
    May 16, 2009
    642
    652
    Oracle DBA
    Skokie Ill
    Would have been nicer if it wasn't so sticky..
    First drive during cottonwood season would have left a fuzzy double stripe
