1st Gen R53 Cooper S Removing pre-cat from stock manifold.
Discussion in '1st Generation: 2002–06 R50, R53 & 2004–08 R52' started by Sleek Motoring, Jan 10, 2015.
  1. Sleek Motoring
    Sleek Motoring Local Shop Owner
    Dec 7, 2014
    249
    143
    Mini repair shop owner
    Colorado Springs, Colorado
    I need to put the stock exhaust manifold back on the R53 to get the baseline HP reading before I start the build.My stock manifold cracked right at the pre-cat.
    Would I be able to remove the pre-cat material (see attached img) without it setting off a check engine light?
    The ModFather may have a stock OEM exhaust you can put on for a base line run. Shoot him a PM.
    Otherwise just stick your new header on.
  3. haygood
    haygood New Member
    Jul 29, 2012
    16
    Texas
    So, did you find out anything about this, Sleek? How about CEL eliminators? These are spacers to push the O2 sensors back a little out of the exhaust flow. They work on Audis with removed pre-cats.
  4. Dave.0
    He used another OEM Exhaust header from a local member for his baseline run.
    He is installing a real RMW header for this build.
  5. Eric@Helix
    Eric@Helix New Member
    1,257
    Shepherd
    Philadelphia
    BTW, when those headers crack there, it's a relatively easy welding job to put them back together. The same holds true for the main cat case which also cracks at the factory weld.
  6. TheModFather
    They dont crack if it sits on the garage floor for a living with a real header on the car...
    Glad Sleek could blow the spiders out of my old OEM one, they had quite the little "Home" going on in there! :)
  7. Sleek Motoring
    Dec 7, 2014
    249
    143
    TheModFather let me borrow his for my baseline run (Thanks again Rick...the spider BBQ went fantastic!).
    Sold my broken one! Still interested if anyone has removed the pre-cat from one of these.
    Would be funny/interesting to hear what a one ball exhaust and gutted pre-cat would sound like! It would be the ramen noodle performance exhaust kit!
