Engine Drivetrain 2nd Gen S Removing the Coolant Tank Fluid?
Discussion in 'Tuning and Performance' started by genik, Jun 19, 2015.
  1. genik
    genik Member
    Feb 20, 2012
    402
    19
    I had to remove/disconnect the coolant expansion tank, set it aside, in order to make room for replacing the stock bov. A lot of coolant fluid was lost as it dripped from the tank. Now that i have replaced the stock dv and installed the expansion tank, i want to know what would the procedure be in order to remove all the remaining coolant fluid and then fill the expansion tank with new!
  2. BlimeyCabrio
    Use a fluid transfer pump, turkey baster, or large syringe with hose, to suck the fluid out of the reservoir before disconnecting it. Will reduce spillage to a few drips, vs. a torrent.
    Or did you mean how do you remove all the remaining coolant in the CAR?
    If that's the question, there's a how-to somewhere for draining the coolant.
  3. ColinGreene
    ColinGreene Well-Known Member
    438
    293
    Orange county Ca
    you can just unbolt it and twist it out of the way, no need to drain it.
  4. vetsvette
    ^^^ Yep, that's the way I did it, and what I do every time I change the erl.
  5. Dave.0
    Just use a straw and suck it out.
    It's good for you and will keep your body warm in the cold Winter months. :lol:
  6. Firebro17
    Get your most annoying neighbor to suck on the straw.
