1st Gen R50 Cooper Replaced Crankshaft Position Sensor O-Ring
Discussion in '1st Generation: 2002–06 R50, R53 & 2004–08 R52' started by zman70, Aug 19, 2016.
  1. zman70
    zman70 New Member
    Aug 5, 2016
    10
    Frisco, TX
    Picked up my '06 Justa a couple of weeks ago. First thing I had to address was an oil leak which appeared to be coming from the crankshaft sensor o-ring.
    Decided to put it in front service mode so I could get a good look at the area. Man, was there a lot of gunk built up around the sensor and really all over that area of the engine. Spent quite a bit of time cleaning everything up. Replacing the o-ring was easy with that much access. Old o-ring was very brittle. Put a little RTV behind the new o-ring (hopefully that will help with future leaks).
    I was worried this car would be difficult to work on with such a small engine bay but it's fairly straightforward to move the front end forward a couple of inches. Not sure how easy it will be to access belt / pulleys but I'll cross that bridge when necessary.
    Yea they are not to hard to work on. I would be careful putting RTV on rubber it can make it slide out, but on the o-ring it should be ok
