2nd Gen R56 Cooper S Replacing the Throttle Body?
Discussion in '2nd Generation: 2007+ R55 through R61' started by genik, Jul 20, 2015.
  1. genik
    genik Member
    Feb 20, 2012
    402
    19
    On a 2008 Mini Cooper S (R56S) as anyone managed -on his own- to remove the Airbox and then remove the throttle body (located on the side of the intake manifold)?
    Im trying to un mount it on my own so any help / tuips on this issue will be most welcome.
    Also, should the battery or other cables be disconnected first in order to avoid further issues?
  2. Zapski
    Any time I swap something electric (with the exceptions of lights) I disconnect the battery.
    But then I'm a computer tech, and that's standard procedure for us :)
  3. genik
    genik Member
    Feb 20, 2012
    402
    19
    After i remove the air box, is it possible for someone to post a pic of the engine so i can understand where exactly the throttle body is located?!
  4. DneprDave
    Have you bought a Bentley Manual? If not, you really should. Otherwise any repairs you do will be like working in the dark.
    The Bentley manual says that the engine control module must be reset after reinstalling the throttle housing or the engine may not start.
    I haven't replaced a throttle body on a MINI, but I wouldn't do it without a Bentley manual, it tells you things like the necessity of resetting the ECU. It is the most important tool you'll have for working on your MINI.
  5. genik
    genik Member
    Feb 20, 2012
    402
    19
    How can i reset the ECU? I have an OBD adapter... would that be ok?
  6. MCS02
    Leave the battery disconnected fo more than 10 min..
  7. genik
    genik Member
    Feb 20, 2012
    402
    19
    Are you talking about an 2008 R56S mini?
  8. nkfry
    nkfry New Member
    Roseville, MI
    Once the airbox is of you will need to remove the charge piping between the long black plastic tube and the throttle body, as well as the noise maker that is routed to the cabin of the car.
    Once that stuff is out of the way there are 3 T30 screws that hold the throttle body on, and one electrical connector.
    I've never had an issue with a car not starting after a throttle body removal or replacement, nor have I had to reset the DME afterwards, but if you are having problems with the current throttle body I would have the DME adaptations reset by a qualified BMW/MINI shop that has access to dealer level computer access.
  9. genik
    genik Member
    Feb 20, 2012
    402
    19
    Anychance of posting photos of the "charge piping" and the "noise maker" so i can understand what exactly you are referring to?
    1. What is the DME and why would that need to be reset?
    2. Can it be reset by an OBD adapter?
  10. Dave.0
    OMG you should not be working on your own car if you are asking these types of questions genik.
    Please have a qualified machanic do the work for you and quit being so cheap.
    All your post are the same. If you don't know how to do something or know what something means try searching YouTube for a how to video or Google a term you don't understand.
  11. genik
    genik Member
    Feb 20, 2012
    402
    19
    Lets not censor questions Dave. Questions help people that want to learn and peaces off people that don't want to help!
  12. _iD
    _iD New Member
    Apr 5, 2014
    62
    23
    Nothing peaces Dave off. ;)
  13. Metalman
    You don't know David.0 like we know David.0.....:D
  14. Savvy
    Except maybe...
