Retrofit questions
Discussion in '1st Generation: 2002–06 R50, R53 & 2004–08 R52' started by SNEEEZY - Erika, Jul 17, 2020.
  1. SNEEEZY - Erika
    1,212
    116
    Female
    I have a 2006 R50 (10/20/06 build date).
    Due to circumstances beyond my control, I am possibly looking for a replacement 2006 R50.
    I would like to know:
    Can a multi-function steering wheel replace a plain steering wheel? If yes, is it a simple reprogramming or ?
    Are all 2006 R50s pre-wired for rear fog lights?
    Can a full toggle bank be installed into a MINI that doesn’t have a full toggle bank? If yes, will reprogramming need to be done? If recipient vehicle has ASC instead of DSC, what is the difference?
    Are all 2006 R50s pre-wired for heated seats? If yes, is it simply swapping over the seats and control panel?
    Do all 2006 R50s have the ability to swap out a plain rear view mirror for the multi-function rear view mirror?
    Are all 2006 R50s pre-wired for heated side mirrors?
    Can non-Xenon headlights be replaced with Xenon headlights?
    Can a climate control panel with the round dials be replaced with the button-type/amber display climate control panel?
    Thanks!
    #2 Crashton, Jul 17, 2020
    Wow Erika a long time since you've been here. Welcome back.
    Not sure about your questions. Hopefully someone will chime inn here with the answers. Sorry about your blue MINI. :Dead:
    Edited to call you by the right name. Doh! o_O
  3. MCS02
    Sorry to see what happened! I cant really answer either. I know some of that is prewired that way they only have to use one harness. But what would work and wont I don't know.
    Glad you're ok.
  4. SNEEEZY - Erika
    1,212
    116
    Female
    Grrr...
    WHY would someone use JB Weld to hold a spark plug in place?!!!
  5. SNEEEZY - Erika
    1,212
    116
    Female
    Will a 2006 R50 engine fit into a 2002 R50?
    If yes, what other issues would I need to be aware of?
    Schultze only needs a few parts plus have the front rails straightened (per Nationwide’s Blue Ribbon shop).
    Absolutely butchery I say. If your engine is good why not have a helicoil put in to repair the spark plug hole? A decent shop can do that for you.
  7. SNEEEZY - Erika
    1,212
    116
    Female
    #7 SNEEEZY - Erika, Jul 17, 2020
    Thanks for the correction.
  8. SNEEEZY - Erika
    1,212
    116
    Female
    It’s not my engine with the JB Weld; it’s the 2002 engine.
  9. wmwny
    4,040
    2,242
    Welcome back, Ericka...sorry about your R50. However, I hope you'll be back and posting here regularly now. It's been awhile.
  10. Minidave
    Most of what you want to do is simple plug and play, however you will need to have it programmed at the dealership.....I'm not sure about the climate control but it makes sense that all the wiring would already be in the car. I know the steering wheel controls, mirror and heated seats all will work.
    2006 engine will fit the 2002 car - but there are some detail differences in the motor mounts and such.....just use the 2002 mounts.
    Fixing a spark plug thread is done all the time, not a big deal at all and does not require an engine change.
  11. SNEEEZY - Erika
    1,212
    116
    Female
    I only mentioned an engine swap because my 2006 has a new head (maybe 10k on it since installation), plus new plugs, oil filter housing, new clutch kit, new flywheel, new exhaust and a few other things. I’ve been the only owner and I know the service history.
  12. SNEEEZY - Erika
    1,212
    116
    Female
    Hi, everyone...
    With 99% certainty, I believe that I have located Schultze 2.0--except he is a 2006 BRG R53.
    The Xenons on 1.0 are undamaged, so I am hoping that I can swap them over to 2.0--is this possible or just a wishful dream on my part?
    The steering wheel on 2.0 is the plain sports wheel--no buttons whatsoever. If I swap over the Multi-Function JCW steering wheel from 1.0 (cruise control, stereo control AND bluetooth phone buttons), what else would need to be done to make the swap fully-functional?
    Climate control: 2.0 has the dials while 1.0 has the digital display--I'm getting conflicting information about whether or not the control panels are interchangeable--and I would love to hear from someone who has successfully swapped these components. I will be getting into the head unit to install my Sirius radio (Lifetime subscription since Day 1!!!), plus swap over Ian Cull's Auto-Up module (yes, I'm spoiled!), so if the climate control panels can be swapped over, I'd prefer to do everything at one time.
    I actually cannot remember if 2.0 has the multi-function rearview mirror or not...if it doesn't, I certainly hope I can swap over the one from 1.0 because I do NOT want to deal with a garage door remote and reaching for the rearview mirror button to open the door has been second nature for a very, very long time.
  13. MCS02
    Wow sounds good. I wish I could answer some of your questions.
  14. agranger
    #14 agranger, Jul 21, 2020
    I'm pretty sure that the fog light wiring is there, but you will need a new light housing/lens/bulb and a new switch panel that includes the fog light switch. I think www.outmotoring.com had that kit for sale at one time (I still kinda crave doing it for Rufus, my current R53).
    Yikes! Almost $450 for my combination of options (almost $400 for the new switch panel + $45 for the light/housing/lens). Maybe I'll just keep myself happy with my current setup. I do wish that all of my switch positions were filled, though... but keeping my wallet filled with 23 more $20 bills is also very attractive.
  15. colinmini
    colinmini Well-Known Member
    441
    So sorry to hear about your R50. And so happy to understand that you are ok. Being the same owner of my 2005 R50 since new, I get what you are hoping to do. Not sure it is cost efficient though. Good luck, hope you find your new MINI and use this to find something different and better.
  16. Dave.0
    • Like Like x 2
    • Agree Agree x 1
  17. SNEEEZY - Erika
    1,212
    116
    Female
    UPDATE...
    I’ve decided not to retrofit the Xenons.
    I’ve discovered that the automatic climate control swap cannot be done.
    I successfully swapped the Homelink rear view mirror, swapped over the Ian Cull Auto-Up unit, ALL of the red bits & bobs that I painted to add pizzazz to Schultze’s interior, and I installed a Sirius-ready Kenwood KDC-BT378U head unit—works WONDERFULLY with the HK system!
    I also swapped over the unique LED tail lights and the InvisiLens anti-reflective gauge lenses.
    I even grabbed my simple, but very useful, Light In Sight fresnel lens for the windshield.
    I also pulled the Parrot Evolution CK3000 Bluetooth components even though I don’t have MFSW on the new MINI.
    I will create a separate thread for MSFW steering wheel.
