RMW's Project X-1
Discussion in 'Car Builds, Projects, Idea's Experiments' started by Jan, Jan 4, 2015.
  1. Jan
    Jan Well-Known Member
    377
    382
    So this has been rolling around in my head for years and finally nearing completion. It will be available in multiple configurations as a turn key track car.........:devil::devil:
    Here we will go through the journey of making a turn key race car from the ground up. All of the people who helped to make this a reality. The many sponsors, friends and family. I can't thank everyone enough. It's been tough meshing everyone together with time lines, health issues, death and about everything else under the sun. I wish I could have gotten this done before my parents passed away. I'm sure they would have been proud.:heart: The car will be at SEMA but it will not be in the final condition as I have other stuff that won't be done. So I will treat you to pics of the car as it has gone from thought process to reality.
    First sponsor: Good Aero LLC, the best wing you can find out there
    the reason it looks like an airplane wing is because it's made in an aircraft facility
    winshield has been laid back 4" for aero:D
    rain gutters etc have been taken off and blended for smooth airflow
    roof is stand length, when we laid back windshield we added to body behind gas cap so car looks proportional. Even Colin didn't notice the windshield was laid back
  2. Jan
    377
    382
  3. ScottinBend
    WE NEED MORE ! !
  4. Jan
    377
    382
  5. Jan
    377
    382
    Tube IN TUBE construction, at key stress points for superior strength
  6. Jan
    377
    382
    How you make a flat bottom and it's setup to run a "sucker" bottom too
  7. Jan
    377
    382
  8. Jan
    377
    382
    the cabin is sealed from the outer shell so air can be run down the inside of the car to duct into the coolers and out the back for minimal drag
    Here you can get an idea of how the air will get down the sides
    as you can see you are sitting in a bath tub of tubes protecting you in event of a crash (even more tubes are added after the above pics)
    the TUBE in TUBE technology in key stress areas will keep the tubes from bending. The tube is welded inside the other then the chassis tube is slid over it and welded again. This is an incredibly strong tube now but it is also light weight for the strength
    the entire car is over built as I want it to do Rally racing and be able to take a hit in door to door
    yes that's a R56 steering rack. Will have 2 modes of steering just like the stock one
    the amount of adjustability in the car is pretty amazing. So much time has gone into the geometry of the arms. I seriously can't wait to drive it. For those that know suspension geometry I think you will be amazed when you see the cycling of the control arms and how it works
  9. Jan
    377
    382
    Custom Bell Intercooler 18"x14"x4.5"
    Hood is vented to suck the air out and over the car
    Couple more sponsors : Driven Steering Wheel and Mastershift paddle shifters
  10. Jan
    377
    382
    Quick update on the fuel cell. It's back from the bladder maker, Aeromotive dual pumps installed with filters, fuel sump baffle/foam, drain etc. It's E85 compatible too
  11. Jan
    377
    382
    Parts of the custom intake manifold
    custom 300M axles , intermediate shaft and input shaft
  12. Jan
    377
    382
    The 2.0L RMW deck plate block is finished
  13. Jan
    377
    382
    RMW custom intake manifold complete for the 2.0L
    Really nice to have room in the car to build a proper length intake runner
  14. Apex
    Apex New Member
    Jan 19, 2014
    96
    NJ
    This build is awesome Jan!!
    What sort of sanctioning bodies are you thinking of running it in?
  15. Jan
    377
    382
    2.0L RMW stroker crank just about finished.............:devil:
    some renderings of what we are shooting for on the look of the X-1
  16. Jan
    377
    382
    it will run in NASA GTS, ST and SU, TTU
    SCCA has a couple also
    We can detune the car with a stock engine and run about 3x as many categories. Good thing is it will be a sorted turn key race car:devil:
  17. Metalman
    Was getting excited about these streamlined babies....:D
    Such clean work Jan....:Thumbsup:
    That car is a work of art! :cool:
    :eek6: Wow!
  20. Apex
    Apex New Member
    Jan 19, 2014
    96
    NJ
    Awesome! Looking forward to seeing this run!
