Brakes Wheels 1st Gen Tires Rotiform Cast wheels: 17x8 et30 fitment & clearance pictures
Discussion in '1st Generation: 2002–06 R50, R53 & 2004–08 R52' started by Rally, Mar 25, 2011.
  1. Rally
    Rally New Member
    50
    Ohio
    I've had a bunch of people ask if I thought the new Rotiform wheels would be a good fit on our cars and whether they poked too much or not.
    What better way to test the fitments than to toss them on the car and see how it looks.
    My car has been converted to 5x112 so you'll see that I'm running the 5 lug versions, but they offer a MINI friendly 4x100 spec wheel in the exact same specs which will fit exactly the same as these.
    Specs:
    17x8 et30
    205/40/17
    Lowered 6+ inches
    Standard factory camber adjustments
    No spacers
    No arch trimming
    Overall the fitment looks like they almost designed the specs specifically for the MINI platform. Even at my extremely lowered height they tuck under the arches quite well and achieve the flush fitment many are after without any fitment issues.
    Great looking wheel with a cool machined finish throughout (although they offer a broad range of finishing options)
    Pictured are both the Rotiform BLQ and the Rotiform NUE
  2. WolfGTI
    WolfGTI Active Member
    May 21, 2009
    387
    217
    NJ
    Lowered MINI's look better than the lowered VW's - the suspension doesn't look like it is broken. But even so, those wheels will rub if the car is driven hard with proper tires. . Looks good though.
  3. Rally
    Rally New Member
    50
    Ohio
    A little rubbing never hurt anyone. We have plastic fenders...
  4. bigfatllama
    bigfatllama New Member
    Jun 21, 2011
    15
    Dubai, UAE
    So the MINI R56 perfectly seats on 17x8 et+30I?
    cuz i wanna order this BLQ rims. your car inspired me replacing my wheels
  5. Rally
    Rally New Member
    50
    Ohio
    Yup, there are now numerous minis running the Rotiform wheels at 17x8 et30.
    With a 205/40/17 tire stretched on, they fit great. You'll want the stretch for the clearance. Running a 215 or a higher profile tire would result in clearance issues when lowered. Look to the Falken 512's or atleast the 912's for the best stretch.
  6. Fracky
    Fracky Club Coordinator
    Apr 6, 2010
    288
    Wow, those rims look fantastic Rally! :Thumbsup: I've dealt with the guys at Rotiform for the wheels on our Audi's & they're first rate. Great customer service.
  7. bigfatllama
    Jun 21, 2011
    15
    Dubai, UAE
    coool! but I need spacers for these wheels with longer studs right? like 15mm spacer?
    I just wanna make things clear before I will set an order and wanna ask advices from you guys cuz I'm not technically inclined. Although I start studying it bit by bit.:wink:
    I'm dying to have this on my MINI. Thanks a lot for the help. Hope this will go through.
    Why would you need spacers with longer studs?
    The wheel goes over the studs and then you put on the nuts. Unless you are using a closed end nut and it is not deep enough to take up all the space between the top of the stud and seat in the wheel. In that case pick up open ended nuts and there is not problem.
    Rally your MINI is looking great!!! :Thumbsup:
  10. Rally
    Rally New Member
    50
    Ohio
    No you don't need spacers and you don't need longer studs. Just bolt the wheels onto your car like normal. I don't have any spacers or anything installed on mine.....just the wheels and some lug bolts.
    Thanks :biggrin5: Waiting to give it a much needed bath and a new set of BBSs for it here shortly.
  11. Tata Steva
    May 30, 2010
    407
    229
    DOP/stock Photography
    TO
    How is Rotiform rim with Brembo JCW BBK on the front? Any issues or need for spacers?
  12. mini9940
    mini9940 New Member
    Apr 27, 2010
    HI there,
    do they do rotiform in 18s for the mini<???????????
  13. Rally
    Rally New Member
    50
    Ohio
    Yes, they should be able to make something work for you. Their 18" stuff is a little wide, but it can fit on a MINI.
  14. XXL1LM1CKXX
    XXL1LM1CKXX New Member
    Jun 11, 2010
    Rotiform ? about R53 and used tires
    I would like to get the Rotiforms. I have Yokahama Avid Envigor tires 205/40/17 with about 10k miles on them. I have rotated them once. They are on S lites atm. Any idea if these tires would work well? If so, should I trust a place like discount tire to mount this set up? I'm scared they won't know about "stretch" or worse will damage the wheels during installation.. any advice would be terrific. Thanks so much.
  15. Rally
    Rally New Member
    50
    Ohio
    You'd have to check the tread and see if you still have any life in them. I can't diagnose them over the internet, unfortunately.
    I generally take my tires to places other than big chains that care a little more about your wheels. Those big chain companies are used to catering to your regular everyday car owner, not enthusiasts. Go to a place familiar with the aftermarket industry that will take care of your wheels and tires and is familiar with short sidewalls, sporty tires, and stretch. They'll get you taken care of and won't damage your wheels. 205/40 on a 17x8 isn't much stretch anyways. They're rated up to 7.5's...so it's only .25" stretch which isn't enough to cause any struggle for the tire mounter.
  16. Tummi_Gummi
    Tummi_Gummi New Member
    Nov 19, 2012
    384
    103
    Online Sales Manager
    Springfield, MO
    How can you turn the front wheels?
  17. iwashmycar
    iwashmycar Active Member
    Jun 1, 2009
    881
    87
    architecture
    Steering wheel
    j/k it's on air
  18. Dave.0
    Bagged cars are all show and no go.
    It's a Cali thing. It works for some, just not my style.
  19. trithumb
    trithumb New Member
    Jul 28, 2013
    looking at 17x8 +35ET front and rear. I am only lowered about an inch and a half from stock. Are these going to be ok? or am i going to have to throw the camber in harder?
  20. Rally
    Rally New Member
    50
    Ohio
    What sizes tires do you plan on running?
    At 1.5 inches of drop, those should work well as long as the tire OD isn't too tall.
