Rough Idle and P1242 Code after some maintenance
Discussion in 'Starting Line - New Member Introductions' started by Texas4Life, Feb 26, 2017.
  1. Texas4Life
    Texas4Life New Member
    Feb 25, 2017
    Military
    Colorado @ the moment
    So I did some maintenance on my 04 mini cooper s which included: Supercharger oil change, water pump, water pump flange, crankshaft position sensor o ring, oil dipstick o ring. So after putting everything back together and starting it for the 1st time I get a code P1242: Secondary Upstream Manifold Air Pressure Sensor Signal Too High in Deceleration. And the idle is fluctuating between 1200-1600 rpm.
    I went looking around I know one of the things too look at is the bpv, which I did and once the engine was up to temp I could clearly see the lever moving back and forth. I also looked at the intercooler boots and they look fine. I also sprayed some of the vacuum hoses, to see if i could get a change in rpm and I didn't et any change. But to be fair the idle is fluctuating so much it's hard to tell. The other thing I did is I unplugged the front MAP sensor, the one by the intercooler, and the idle dropped back down to 900-1000 rpm. Not sure if that's normal or not. Any ideas?
    After doing some work on my 02 I got the same code and found this unplugged, But my idea was steady.
  3. Texas4Life
    Feb 25, 2017
    Military
    Ok for anyone that has this issue it ended up being the vacuum hose under the MAP sensor had broken.
  4. 00Mini
    2,227
    Good to hear that the problem has been corrected and thanks for the update.
