1st Gen R53 Cooper S S/C Boost Disappears...
Discussion in '1st Generation: 2002–06 R50, R53 & 2004–08 R52' started by MyFunkyMINI, Oct 12, 2011.
  1. MyFunkyMINI
    MyFunkyMINI New Member
    Oct 11, 2011
    14
    After the car heats up.
    Causes?
    Solutions?
    I just installed the DT Bypass Valve, but had the same thing goin' on before.
    TIA!
  2. miniconcarne
    miniconcarne New Member
    38
    Machinist
    Home
    Leaky boots was my problem, put new silicon ones on, problem gone.
  3. HRM
    HRM New Member
    Mar 16, 2011
    74
    10
    That sounds like a good place to start, especially if you have non-stock ones, but as it heats it may leak. If you are lucky, when you examine them you will see an obvious issue.
  4. quikmni
    quikmni Moderator
    Jun 6, 2009
    774
    174
    Aerospace Engineer
    Orcutt, CA
    I agree, check the IC boots.
    I went back to OEM boots after using aftermarket silicon boots because the silicon where difficult to get on and did not seem to fit as tight as the OEM style.
  5. agranger
    1,486
    Interesting. I had a leak, but the dealership tech suggested that I get some of the heavier silicone IC boots. On my GMRS intercooler, they seem to get a better fit (though perhaps that is because the GMRS input and outputs aren't a great match to the OEM... close, but not perfect).
    Using the OEM IC, I'd bet that the OEM boots get a better seal.
  6. BThayer23
    Another trick is to sand down the ends of the clamps, so you can squeeze a little tighter.
    Color me as another that went the way of Silicon boots and then went back to OEM. That's not to say OEM is perfect, just better. They do need to be replaced now and then too. Change mine with every Coil, Plug Wire, Plug change. For me that is an annual event.
  8. minimark
    You change the coil every year??
    Yep, back to OEM boots for me also...
  9. Nathan
    Coil and Plug Wires, once a year in the spring.
  10. MiniPilot
    MiniPilot New Member
    Aug 10, 2011
    Colorado, gotta love it!
    Just curious, do you change the plugs etc every because of mileage, just time to do it, or...? I've owned mine since April and am wondering what to do for preventive maintenace. ( Maybe should be a new thread?) Still trying to et comfortable with 15k oil changes!:eek6:
    We should probably start a new thread to discuss.
  12. minimark
    Yes
  13. ScottinBend
    Still loving my Alta couplers..........very tight and no leaks.
    There is a trick to getting them on with little drama. Just loosen the front mounts and you can move the IC around to get the boots on much easier.
