2nd Gen R56 Cooper S Sad Day
Discussion in '2nd Generation: 2007+ R55 through R61' started by tmancoopers, Oct 9, 2014.
  1. tmancoopers
    tmancoopers New Member
    Sep 21, 2013
    21
    Hello,
    First off i would just like to say that my one year with my mini has had its up, but its definitely been out weighed by its downs. such a great car but with such great faults.
    Lemme just bring you guys up to speed. In June of 2014, the infamous timing chain tensioner decided to call it quits on me. spilling all the oil, and splashing it all over the engine bay. obviously i was furious since i only had the car since september of 2013. Now, i got the timing chain tensioner and the timing chain all replaced, and i only got it back last week. I know it took 4 months to do but i gave it to my buddy and told him to take his time, it was the heat of summer so i just rode my motorcycle instead. about 800$ and 4 months later, the timing chain is repaired and car is running again. HOWEVER, in the midst of oil splashing everywhere, the burning hot oil made its way to my ECU, causing even more problems, the check engine is implying faulty HPFP readings and accelerator problems. Basically, weve tried everything to repair the old ecu and came to the conclusion a new one is required. my buddy being very old school and not very aware on the internet and what not, called up mini to get a new ECU. they were quoting us close to 2000$ for a new ECU and a reprogram.
    Now for my question, after some extensive online searching, i found some used ECUs that have been refurbished and apparently are ready to install (no need to program). first of all, does that make sense to any one you? second of all, they require a ECU ID to ship out the right one, how do i find this ID? I managed to locate the ECU, with difficulty pulling it out, i decided to mark down some numbers already visible on the ECU and see if i can cross-connect them to the ID. what i found was DME 7610107 corresponds to ECU ID 1214 7 630 107 and ECU ID 1214 7 610 107. Can anyone confirm this? If not explain where exactly i can find the ID.
    Now my cheapness is wondering if i can just go to a scrap yard, find an ECU with the matching ID, and just plug and play. Is this an option?
    Sadly, after the ECU is repaired, Cleo, my mini, will be put up for sale. thats the sad part of this all.
    Any help would be useful guys, im really in a jam, summer is over and i need a car to drive, i cant keep borrowing my moms car and its too cold for the bike.
    Thanks in advance
    mike
    Thats a shame...
    The ECU is keyed to the VIN and the Body Control Module. Someone that access to the MINI/BMW Software will need to program the car.
  3. tmancoopers
    Sep 21, 2013
    21
    so if the website selling the ECU is asking for my VIN, chances are they are going to program it to that VIN?
  4. Minidave
    4,594
    Are you sure you need an ECU? I can't imagine oil getting to the ECU or causing a problem with it. You sure you don't have a HPFP issue? Cause that's far more likely than an ECU problem, plus there's huge warranty extension on them .
    If you are sure, then I don't think they can pre-program an ECU, my understanding is it has to be on the car......but I could be wrong about that.
  5. mrntd
    That's a good question to ask them. Don't take it for granted. The ECU does need to be matched. Make sure the people your getting it from are doing that.
    After you sell you R56. Find a nice '05-'06 R53 and enjoy it.
  6. minsanity
    minsanity Well-Known Member
    Sep 11, 2009
    581
    352
    +1. Hope you get it sorted. Have the pump checked.
    Old school guys stick with gen1s where the language is still comprehensible. I'd never go near a gen2, much more a gen3. :D
  7. Dave.0
    All good advice above in this thread. Have other things all checked out even buy a MINI dealer before you buy a Website ECU.
  8. tmancoopers
    Sep 21, 2013
    21
    I haven't checked the codes myself but apparently there is one code identifying the HPFP is faulty (which i know is under warranty) and another indicating that the acceleration pedal isnt giving a proper signal. basically what happens, the car starts rough, then if i press the gas, i cant pass 3000rpms. acceleration is very slow, and even if i floor it there is no response by the throttle. i should probably just bring it to mini and get their opinion
  9. Dave.0
    The HPFP is faulty and that will cause all the above problems take it back to the dealer and let them deal with it.
  10. Metalman
    If it were me I'd get it checked out by a MINI specialist first.... The option of throwing parts at it is always expensive...
  11. Tummi_Gummi
    Tummi_Gummi New Member
    Nov 19, 2012
    384
    103
    Online Sales Manager
    Springfield, MO
    Sometimes people cross reference vin numbers for model design and manufacturing date. So I wouldn't assume anything.
