1st Gen R53 Cooper S Sagging Headliner: advice for DIY fix
Discussion in '1st Generation: 2002–06 R50, R53 & 2004–08 R52' started by fridayxiii, Dec 9, 2014.
  1. fridayxiii
    fridayxiii Member
    Mar 7, 2013
    86
    49
    Tampa Bay, FL
    And no, I'm not referring to a poorly-aging rockstar :lol:
    The headliner in my '06 is starting to sag somewhat over the rear seats, which I happened to notice via the rearview mirror last weekend.
    I'd like to make the repair as quick, easy, and cheap as possible. Since it's just sagging, I was wondering if I could use an Xacto knife or similar very sharp blade to slit the headliner where it meets the rubber trim at the top of the boot opening, apply some appropriate glue, then pull tight to remove the sag.
    Has anyone done this, or have alternate advice? Was hoping I could DIY instead of going to an interior/upholstery repair shop if possible.
    Thanx!
  2. Minidave
    #2 Minidave, Dec 9, 2014
    In a word......no.
    There is no cheap easy fix......
    The headliner is made of fabric glued to foam glued to cardboard, it's the foam that's failed. The only fix is to take it out, remove the cover, scrape off all the foam.
    Then buy new fabric with the foam already glued on and re-glue it to the cardboard.
    It sounds harder than it is, I've done several of them.......
    If you want to save some cash, maybe remove the headliner, scrape it down clean and then take the cardboard part to the upholstery shop and have them cut and glue the new material on, then you re-install it.
  3. ScottinBend
    Do you have a sunroof? If so, could it have leaked and caused it to sag?
  4. Dave.0
    You really need to look at a persons garage before asking a silly question.....:lol:
    He has 5% tint on sunroof
    _______________________________________________________
    fridayxiii Yes you should do what exactly what MiniDave said above.
    I just did mine and it not that hard to take out.
    I pulled all the fabric off because the glue between the foam and the fabric failed. New glue will not stick to the dry rotted foam.
    After you take off the fabric use a steel bristle brush and the glued foam comes right off old glue and all.
    Then you can pick your fabric and get some good 3M glue and do it yourself.
    (not worth it)
    Or do what I did take it to an auto upholstery shop and have a professional do it for $100.
    In the end it will look better then the OEM one. They will use the correct glue, foam backed fabric and professionally trim and glue wrap all the edges for you.
  5. fridayxiii
    fridayxiii Member
    Mar 7, 2013
    86
    49
    Tampa Bay, FL
    Thanks guys, appreciate the input & tales from past experience. Looks like I'll be enlisting the help of a trained pro for this one.
  6. Minidave
    If you don't have a large, clean, warm place to work, that's probably the best idea. Pretty much all mfrs have been doing it this way for years and years, so any decent upholstery shop will have already done hundreds of them.
    It's a little tricky around the sunroof, but again, a good shop won't have any problem with it.
  7. ScottinBend
    :p
  8. mrntd
    I have fixed it on a different car with your idea using 77 spray adhesive. BUT if the foam is disintegrating as others have mentioned this is only a temporary fix.
  9. minsanity
    minsanity Well-Known Member
    Sep 11, 2009
    581
    352
