Interior 2nd Gen Screw Cap Removal For Blinders Help...
Discussion in 'Tuning and Performance' started by Systemlord, Mar 6, 2014.
  1. Systemlord
    Systemlord New Member
    Mar 28, 2013
    311
    67
    One of my blinders on the passengers side is loose because the screws are loose, how do I remove the plastic caps to access the screw itself? I'm not sure where there hinged or which side to pry from, I'd like to get them out without damaging them.
    Much appreciated!:wink:
  2. Jason Montague
    :cornut: Look in your Bentley Manual and it will tell you. That's all that I know to tell you. But this post will act as a 'Bump' also.:Thumbsup:
  3. Systemlord
    Mar 28, 2013
    311
    67
    I don't have a Bentley Manual yet, I plan on getting one in the next month or two.
  4. mrntd
    I use a very thin bladed small flat screw driver and wiggle it gently.
  5. maacodale
    maacodale Club Coordinator
    255
    Poquoson, VA
    /\ CORRECT/\
  6. Norm03s
    Norm03s New Member
    534
    Working at being retired.
    Somewhere in Sykesville. Md.
    Caution, don't over tighten those screws and strip them, just snug.
    Maybe a bit of 242 loctite to keep them from re-loosening.
  8. Justa Jim
    A wrap or two of electrical tape on the screwdriver prevents scratching.
  9. Dave.0
    I use a little hook tool or a tiny screw driver and they pop right out.
    I use the cheap cream colored masking tape over Electric tape just because 3M Black Electrical tape can leave a little black glue behind but it will wipe off.
    I am not sure where you are located but be careful if its very cold out because if you pry to hard you can crack or brake them. Warmer the better and they will be more flexible and come right out.
    Photography gaffers tape. Leaves no residue & does the trick. Don't use Uncle Red's favorite.
  11. Dave.0
    Also works to keep people quite in your trunk while you take them out to the woods. :rolleyes:
  12. ScottinBend
    Or get a set of those plastic body panel removal tools. Best investment ever.
  13. Dave.0
    ^^^ Yup :Thumbsup: I have a set of those and they work great if you are doing that kind of work all day long.
    I have a set of those & yep they are great. I don't think I have one thin enough for those visor screw covers.
  15. Norm03s
    Norm03s New Member
    534
    A set of jewelers screw drivers is handy for this.
  16. Dave.0
    or you can go old school and just use a tooth pick as it will break before you can do any damage. :Thumbsup:
  17. Angib
    ....before it can do any damage to the plastic trim, I think you mean.
    The end will fly off the tooth pick and damage your eye, but you can tell the ophthalmologist at least your car's plastic trim is OK....
    Always follow the Health & Safety dept rules when working on such dangerous things. Proper attire is paramount!
  19. Systemlord
    Mar 28, 2013
    311
    67
    I also thought about using a toothpick. It's a good thing I wear glasses.
  20. vetsvette
    +1 for the Non-marring trim tools. <$10 at AutoZone and useful for many Mini applications. :)
