Engine Drivetrain 1st Gen Cooper S Seafoam treatment today
Discussion in 'Tuning and Performance' started by Mr. Jim, Nov 12, 2010.
  1. Mr. Jim
    So i was getting ready to give RDZNL the first seafoam since I've owned it. I've got the baby sledge on the gas pedal maintaining 200 rpm and starting to introduce it into the hose, when i start seeing flames coming from the rear of the engine :eek:
    Seems that when the dealer replaced the leaking valve cover gasket, or did they (under warranty) oil was or had been dripping on the heat shield and I guess the sustained idle and not moving air over it, ignited the oil! So I got the extinguisher and put it out without making a very large mess, just cleaned the MINI yesterday :mad5:
    Anyway, finished the treatment, let it sit, started it up and fogged the neighborhood and took a blast down the parkway, it stalled a few times coming back at the lights but we'll see how it goes tomorrow, worse case I'll have to get some new plugs.
  2. Justa Jim
    Mine sputtered a bit as well, but worked through it. I think the ECU gets all confused about what is in there. I put it in the gas tank once and will NEVER do that again.
  3. Mr. Jim
    Yea, i read several threads about people doing that so I didn't do that. I've used seafoam for years on higher mileage vehicles and hadn't heard of using it earlier until we got the MINI and then I waited till it had 40,000 miles to use it. :Thumbsup:
  4. iwashmycar
    iwashmycar Active Member
    Jun 1, 2009
    881
    87
    architecture
    Last time I Seafoamed I think I revved it while it was still sputtering and it threw a CEL for about 200 miles afterwards. I just did it again last weekend and it went well. Then I got gas the next morning and bam... CEL. Not sure if it's related or not. Hope it is.
    Sent from my Verizon Wireless Phone
  5. Mr. Jim
    So far so good. Did you try to clear the code?
  6. iwashmycar
    Jun 1, 2009
    881
    87
    architecture
    No not yet, I figure if its easily clearable, itll go out in another 60 miles or so lol
  7. TGS91
    TGS91 New Member
    May 8, 2009
    1,593
    Sales Dude
    St. Louis, MO
    How much did you put in? I put in about a 1/3 of a can and no problems and it seemed to clean out the injectors nicely
  8. iwashmycar
    Jun 1, 2009
    881
    87
    architecture
    Had Advance Auto pull codes and it was Misfire on 3 of the 4 cylinders. Im sure it would have went out soon, but I had them clear them. No more CEL.
    Kind of a pain always getting a light, so I just wont Seafoam again for a while....or maybe just use less than a 1/2 can
  9. Mr. Jim
    How new/old are you plugs? I think the amount is ok, I used almost the entire can as I couldn't get it to stall out with just 1/3. My plugs have about 10,000 on them. It didn't start after 5 minutes so I let it sit longer and it fired right up.
  10. iwashmycar
    Jun 1, 2009
    881
    87
    architecture
    Replaced them about 2 weeks ago, so theyre good to go. Even ran a lot better afterwards (plugs) . Same gap and all
    It definately had a good stutter going after the foamage. I think it was just after I did it I drove home from work (where i had foamed it) and then it sat all night and then I got gas 1/10 mile away and restarted. Probably still had some residue in it which tripped the knock sensor or whatever.
  11. Mr. Jim
    Yea, should be good to go then. I haven't taken a long ride yet since the initial run but it's starting right up and idle fine.
  12. Justa Jim
    About the same, but mine acted real funny and the mpg went south until I could put in new gas. I believe the manual says NOT to use any gas treatment, but it was too late then.
    I use Chevron Techron in my tank & have never had any issues. Although I do not have a R56 so maybe that is the difference.
  14. Mr. Jim
    I use the BG 44k and never have any problems in any of my vehicles.
  15. TGS91
    TGS91 New Member
    May 8, 2009
    1,593
    Sales Dude
    St. Louis, MO
    I know there are some different usage instructions floating around. One I saw from OxyBlue, I thought it was, suggested using 1/3 can and letting sit about 20 min. Also your looking to not stall it out although you will certainly cause some sputtering.
    I've done this 2X now and I get a crap load of gunk out if the smoke is any indication and no CEL's
  16. Mr. Jim
    We've always used it to stall out at the end, this way there is enough sitting in the cylinder to loosen the carbon while sitting. Never had any SES lights on any vehicles we done over the years.
