Interior 1st Gen Seatbelt adjuster
Discussion in 'Tuning and Performance' started by MCS02, May 30, 2015.
  1. MCS02
    A friends 2004 R53 seatbelt adjusters are stuck in the full down position. I can not get them unstuck.
    Anyone know how to get them to move?
  2. Norm03s
    Norm03s New Member
    534
    Working at being retired.
    Somewhere in Sykesville. Md.
    Nope, I would start by taking it apart, that maybe a mistake though.
  3. ScottinBend
    Is there any slack available? If there is and you can't get the lock to release then the mechanism is probably stuck. Had this problem on an older car of mine and it took opening up the trim and lubing up the mechanism.
    Extend and Retract - How Seatbelts Work
  4. Spa2k
    Spa2k Well-Known Member
    May 9, 2013
    1,955
    975
    Iowa
    Try unbolting it from the B pillar if you can to get a little slack in the belt. If that doesn't work, take the cover off the roller and see if the belt is twisted inside. One or two twists can really jam things.
  5. MCS02
    Thanks guys! But its the hight adjuster that won't work. Sorry I should have read what I typed. The seat belts work fine.
  6. MCS02
    It looks like the inner tab was on top of the outer. Its fixed.Thanks everyone
