Brakes Wheels 2nd Gen Tires Securing the Valve Stem Caps
Discussion in '2nd Generation: 2007+ R55 through R61' started by genik, Dec 21, 2013.
  1. genik
    genik Member
    Feb 20, 2012
    402
    19
    Its the 2nd time that somebody stole all four Valve Stem Caps from my R56 wheels! Is there some way i can prevent burglars from steeling them?
    There are locking valve stem caps on the market. Usually held in place with a set screw so one needs an allen wrench to remove them.
    See [ame="http://www.ebay.com/itm/ANTITHEFT-LOCK-Wheel-Tire-Valve-Stem-Cap-MINI-CLUBMAN-COUNTRYMAN-COUPE-PACEMAN-/141028511869?pt=Motors_Car_Truck_Parts_Accessories&hash=item20d5f4507d&vxp=mtr"]Antitheft Lock Wheel Tire Valve Stem Cap Mini Clubman Countryman Coupe Paceman | eBay[/ame]
    I'd also check with the M/A sponsors too. OutMotoring may be the place for this item.
  3. Norm03s
    Norm03s New Member
    534
    Working at being retired.
    Somewhere in Sykesville. Md.
    Warning,
    my brother bough some fancy aluminum valve caps for his Vette. They oxidized on to his valve stems, he had to have the valve stems replaced so he could add air.
    Good call Norm. Galvanic corrosion from dissimilar metals. The guy at my local tire place warned me of this. I had some chrome metal ones on my wife's MINI. Now it wears plastic ones.
  5. ZippyNH
    You can get brass ones with a tiny o-ring on the inside...the outside is chromed....that way it is brass on brass...worried...add a tiny dab of lube on the threads to prevent corrosion.
    I'm staying with the plastic ones Zippy. Less unsprung weight. :smilewinkgrin:
  7. genik
    genik Member
    Feb 20, 2012
    402
    19
    thanks guys, i think ill go for the plastic ones, its just not worth getting angry some one you don't know! probably put on an alarm on too!
  8. Dave.0
    I put a little candle wax on the stem and rub a little in the caps and it keeps them from getting oxidized together. :Thumbsup:
    But it won't help them from getting stolen.
  9. Firebro17
    #9 Firebro17, Dec 21, 2013
    Just buy the brass/chrome ones with the 3/8" hex heads. Tighten them up and keep the wrench in the glove box.
    If the little bas***** (er, uhh, punks I mean) get 'em after that, it was meant to be..... :beer
  10. wmwny
    4,048
    2,246
    I wonder if some Locktite or fingernail polish on the threads might keep the kiddies from stealing your caps.
  11. genik
    genik Member
    Feb 20, 2012
    402
    19
    Due to my inadequate english i dont really understand what the effect of all that (Locktite, fingernail polish) will do. Plz explain further! :eek:
  12. wmwny
    4,048
    2,246
    Both act as an adhesive [when dry] that keep screwed in nuts [in this case, tire valve caps] from loosening easily. The Loctite is especially made to do this but the fingernail polish does a credible job, too. When they are dry, it takes a bit more than just fingertip pressure to break the seal to remove the nuts [or, in this case, the caps]. Usually pliers can be used to break the seal and most kids do not run around with pliers in their pockets...lol.
    What kind of fingernail polish do you wear Jeff? :wink:
  14. GokartPilot
    GokartPilot Well-Known Member
    Jan 9, 2012
    967
    727
    training specialist
    Maysville, North Carolina USA
  15. Norm03s
    Norm03s New Member
    534
    Now I wonder:idea:
  16. wmwny
    4,048
    2,246
    Cute, Chuck, m'boy. Actually, it was a tip in an old Popular Mechanix magazine that I read while growing up. Like a lot of kids back in the day, I had a go kart and the lock nuts that held the engine onto the frame always worked loose [so much for "locking"...lol]. The magazine suggested nail polsih, but later in life, I read somewhere about Loctite doing the job, too. The nail polish tip is a helluva lot cheaper than Loctite, though, and the only downside is having to put up with my fellow M0M curmudgeons. :devil:
  17. Firebro17
    ^^^ Not if you're buying the same polish my wife is....
  18. Nathan
    That and staring at the nail polish rack for hours to get that perfect shade just for you. :biggrin5:
  19. wmwny
    4,048
    2,246
    I like to match the colors of my MINIS...Royal Grey, Pepper White, and Silk Green. So, as you can see, the time spent is not that much and one bottle of each will last the life of each car! :devil:
  20. Dave.0
    ^^^^^ :lol::lol::lol::lol:
