Service Bulletins
Discussion in 'MINI' started by YeloMini, Nov 7, 2010.
  1. YeloMini
    YeloMini Member
    Jul 7, 2009
    234
    #1 YeloMini, Nov 7, 2010
    How about a thread with bulletin numbers? These seem to pop up randomly in threads as issues are worked out. Would be nice to have a concise list in one place.
    I'll start with the ones I'm familiar with or have seen recently (R56).
    SIM 64 02 08
    Heat in the drivers foot well (insulation is installed on heater core piping)
    SIM 22 01 08
    Transmission mount (knocking sound from front of car)
    SIM 33 01 07
    Rear sway bar bushings wrong from factory (knocking sound from rear of car)
    SIM 11 02 07
    Cold start rattle
    SIM 54 04 06
    Upper dash rattle
    SIM 51 08 07
    Remove dash and insulate contact points
    SIM 64 01 10
    Noisy air conditioning
    ?? Sunroof SIM 54 01 07
    Seat heaters too hot or too cold
  2. ScottinBend
  3. CarlB
    CarlB Active Member
    54
    Great idea - Can they go in the library?
    I'm looking into this. From first glance it will require a database and search function as there are 467 Service Bulletins from 2001-2010 models at this point. I looked into purchasing an AllData subscription but BMW/MINI is not listed. In fact most of the German Automakers are not listed on AllData.
    I've looked into getting this info from a friendly dealer too, however, they state that MINI codes the bulletins for each dealer and comes down on dealers making this info public.
    I've put on my white board as a long term project to obtain, maintain and keep a TSB listing.
  5. BThayer23
    Maybe the TSBs from the dealer could be redacted, CIA style, to preserve confidential sources?
  6. CarlB
    CarlB Active Member
    54
    Thank you Nathan – I am surprised they make it so hard.
  7. YeloMini
    YeloMini Member
    Jul 7, 2009
    234
  8. Yeah BB
    Yeah BB New Member
    Jul 11, 2010
  9. Rixter
    Rixter Well-Known Member
    Jun 14, 2009
    1,230
    79
    Technology Architect
    North of the 49th
    Nate, not that you have a lot of spare time on your hands, but also if anybody has a PDF of the SIM bulliten that would be very helpful too. Just to add more work, what about recalls (which there hasn't been yet) or warranty extensions, such as with HPFP
  10. YeloMini
    YeloMini Member
    Jul 7, 2009
    234
    Updating the original with one I had for the cold start issue.
    It looks like this PDF answers one of my other questions, according to the footer on that PDF, the TSB wording is on the Minitis pay site.
  11. cop1406
    cop1406 New Member
    Jan 6, 2010
    64
    6
    Oink Oink
    Sonora, CA
    Does MINI ever notify owners about TSB's or do they fix them automatically when you take them in for service. Seems kinda odd that it is up to the owners to find the TSB's and have their cars fixed.
    #12 Crashton, Nov 30, 2010
    The way I have seen it work is if an owner comes in with a complaint that there is a TSB for they will fix it. Come in without the complaint & it doesn't get fixed or even mentioned. Knowledge is power, print off the TSB & show it to the nice SA.
    I had a certain unnamed SA at an unnamed dealer lie through his teeth about a TSB for my MINI. MINI used the wrong trans fluid in LSD equipped cars. We went round & round for a while with him denying such a TSB existed. He did offer to change my trans fluid for their going rate though. I then handed the nice man a copy of MINI's TSB. He turned red & said OK we will do it. I had a bit of fun asking him why he felt he needed to lie to me. Was it because 2 quarts fluid was too expensive or was it the 10 minutes of shop time? Never did give me an answer to that. :eek:ut:
    This is a great service to owners to list all know TSB's on M/A. :Thumbsup:
    A big thanks to Yelo!!! :cornut:
  13. Rixter
    Jun 14, 2009
    1,230
    79
    North of the 49th
    Thanks Yelo! :Thumbsup:
  14. YeloMini
    YeloMini Member
    Jul 7, 2009
    234
    Added an older one I found to the original post.
  15. TheCheatOSX
    TheCheatOSX New Member
    Jan 24, 2011
    27
    #15 TheCheatOSX, Mar 17, 2011
    All the TSB PDFs that I've found from the TIS:
    R56 TSBs (Mediafire shared folder)
    You should be able to link each up to the original post as they are individual PDFs. 22 so far! More will be added as I find them.
  16. Metalman
    Nice bit of information you supplied. Thanks:Thumbsup:
    Down loaded, ran hard copies, pages inserted in my MINI binder.:D
  17. TheCheatOSX
    Jan 24, 2011
    27
    Keep checking back, I keep finding more!
  18. Minidave
    4,593
    Something to be aware of, not all the 2nd gen bulletins apply to all the 2nd gen cars.
    For example, I complained loudly that my seat heaters were too damn hot, the dealer "checked" them and said they were in spec. Later I found the bulletin with the resistor cable and tried to get them to install one under warranty and they said my car already had the cable in it, that all the cars did after a certain year/serial number.
    None of this made my seat heaters any more comfortable to use, so I ordered the cable myself (only $17 btw) and I'm going to see if I can daisy chain them and cool things down to a reasonable level.
  19. TheCheatOSX
    Jan 24, 2011
    27
    Up to about 70 files now. That will be all for awhile. :crazy:
  20. ScottinBend
    Any chance of getting some 1st gen ones posted?
