2nd Gen R56 Cooper S Shark Injector ECU REFLASH
Discussion in '2nd Generation: 2007+ R55 through R61' started by oldvet53, Dec 19, 2012.
  1. oldvet53
    oldvet53 New Member
    Oct 21, 2012
    277
    79
    Disabled/Retired
    N.E. Arkansas
    Has anyone tried the Shark Injector ECU Reflash? It was developed by a former BMW ECU programer, it is supposed to raise the rev limit and remove the speed limiter and you tell them what mods have been done and then it is flashed before it gets sent to you and hooks up through the OBDII port. I would ave to go to Oklahoma,Texas,Mo., or other long distance trips to get a tune and was just wondering if anyone had tried it or heard anything good or bad about it.
  2. Eric@Helix
    Eric@Helix New Member
    1,257
    Shepherd
    Philadelphia
    I have. Programmed by Jim Conforti, an early chip tuner who had some success in BMWs in the 90s. The Shark Injector increases timing and takes fuel away. I have seen fewer than 10 bottom end failures on R53 cars over the years: three of them had the Shark Injector in them.
    Not complaining, just explaining.
    BTW one of those cars was what later became the Wildebeest. Somebody else's misery became my joy. Sorry.
    Recycling is good for the environment. :Thumbsup:
    The Shark Injector was viable a few years ago before better options came along.
    Another one you will probably see if you search around a bit is MTH. Was all the rage for a while, now not so much.
  5. Dave.0
    When I hear Shark injector I hear the theme from Jaws.
    Da dum
    Da dum
    Da dum
    BOOM!
    REBUILD TIME!
  6. oldvet53
    oldvet53 New Member
    Oct 21, 2012
    277
    79
    Disabled/Retired
    N.E. Arkansas
    You guys on the east and west coast have it easy with all the tuners localy. All around me require a appt;, a 500 mile or longer drive one way and a motel to spend a day or two to get a tune and a chance to get on a dyno.
  7. MCS02
    6,278
    I feel your pain. I'm in the same boat Memphis doesn't have any one ether
  8. ZippyNH
    Good thing about tge mini is you can do an amazing amout of mods before you really NEED a tune to get the car running right. Wanting is another...but many places CAN put a canned tune on you ecu...just ship it off to wmw...pay for overnight....and in a few days, you can have a decent canned tune.
    Just remember, canned tunes are less tolerant of future mods than the stock tune...so finish all you motor mods, THEN TUNE. Vonsider to be an ending step, unless you want to retune...so it gets $$$.
  9. Way Motor Works
    Way Motor Works New Member
    206
    MINI Tuner
    Atlanta
    FACT: The shark injector only advances the timing (ALOT) and bumps the rev limiter. it does nothing else.
    We have retuned many cars that had the shark injector and this is what we saw on each of them. I don't recommend it.
