Should a Boost Gauge show Vacuum?
Discussion in 'General Technical Questions and Answers' started by Kellen@Craven, May 20, 2013.
  1. Kellen@Craven
    Kellen@Craven New Member
    36
    Talking about Minis and stuff
    Portland, OR
    Let's say you were designing your own boost gauge, would it be just a boost gauge or would you want to see it display vacuum as well? I would like to hear your thoughts and have a conversation about it...
  2. Mr. Jim
    Should display both as the gauge will see both conditions. Vacuum lets you know how your engine is running also. My 2 cents.
  3. Kellen@Craven
    36
    Portland, OR
    Thanks for starting Mr. Jim. If the gauge shows vac, should it be on the same scale, or do you just want to know that there is vacuum at all?
    The trade-off would be the amount of sweep available for boost readings. If half of the gauge is the vacuum side of things, then it becomes tougher to distinguish between 12 and 13 psi, right?
  4. DneprDave
    In the USA, the vacuum should be in inches of mercury and the pressure should read in pounds per square inch.
    Or in Europe, vacuum in millibars and pressure in bars.
    Dave
  5. BlimeyCabrio
    This is a valid question.... Just because the gauge will "see" vacuum doesn't necessarily mean you have to display that. I get where you're coming from, Kellen.
    Lots of folks have no real idea what the vacuum numbers mean... Nor interest in them. But have lots of interest in accurate boost....
  6. BThayer23
    Vacuum shows you when the bypass valve opens. Otherwise, not as useful as boost.
    I limped my car home from the track one time with a busted crank pulley - kept the car in vacuum around 45mph and it didn't throw codes or go into limp mode. But that was not a typical situation.
  7. Dave.0
    The one I have shows vac and boost. I like it to show both.
    Here is the one I have:
  8. SacredDisorder
    SacredDisorder Because Race Car?
    209
    54
    Iott Ranch & Orchard
    Petersburg, MI
    I think Vacuum is a useful thing to show on the guage. Seeing how much vacuum your car pulls on a day to day basis can help to diagnose problems later down the line. Most electronic monitoring devices don't record the full readings of vacuum like a guage does either. My access port and REV for iPhone both show a max of 10-12 inches of mercury but my pro sport boost guage reads 23 inches while off the throttle coasting and 20-22 inches while at idle. Personally this is information I like to have.
  9. CarlB
    CarlB Active Member
    54
    SacredDisorder is correct, vacuum gauges are helpful. You can diagnose the condition of your engine. If you know the engine pulls a specific amount of vacuum at idle and things change you know you have a problem. If the needle is bouncing around you might have a burnt valve or bad rings. Then you know you need to do a compression test. You can see how the bypass valve is working, and tell the difference when you install a Detroit Tune bypass valve. You can know to look for a leak in a vacuum line if the reading goes down from normal.
  10. Nathan
    Yes, there should be a vacuum side to the gauge.
  11. CHKMINI
    Dave, who's gauge is that. I like the face because it matches close to the JCW gauge faces.
  12. Kellen@Craven
    36
    Portland, OR
    Okay, so looking at that X-Line gauge that Dave.0 posted. It shows +/-30 with a lot more real estate being granted to the boost. Looks like about half the face. It seems that most of you feel like the vac side is important, are you happy with 1/4 of the gauge being used for accurate vac readings? Would 1/2 the gauge allow enough movement on the boost side to allow you to be able to quickly tell what the reading was?
  13. Mr. Jim
    I have the stock boost gauge and its half the gauge with zero at 12 o'clock. Either way the your only using 1/2 to 3/4 of both sides. You'll never hit 30" vacuum, lets hope not and never full numbered boost.
  14. CHKMINI
    Personally I like the look of Dave.O's X-Line gauge and also like the dark face that matches the JCW dark gauge faces.
  15. Metalman
    Vacuum info is great to have but I feel it's important to show more sweep on the boost side to better see smaller increments of boost...
  16. Kellen@Craven
    36
    Portland, OR
    So, if it were up to you metalman, you'd have the gauge use just a little space to show vacuum on a reduced scale. Thus, leaving most of the gauge to show fine increments of boost. Still reading from 30 to 30 like that X-Line?
  17. DneprDave
    I use the vacuum part of my boost gauge, when I'm trying for maximum miles per gallon.
    If I keep the gauge in maximum vacuum for conditions, the mileage goes way up.
    Dave
  18. anuppercasej
    anuppercasej New Member
    Jun 11, 2010
    185
    38
    Portland, OR
    I think it should show vacuum as well. I like seeing the gauge be a little more active.
  19. Dave.0
    Yeeeeeah I only see vacuum when stopped.:devil::lol::Thumbsup:
  20. Metalman
    Yep...
