2nd Gen R56 Cooper S Skid plate?
Discussion in '2nd Generation: 2007+ R55 through R61' started by OhBe1, Sep 17, 2012.
  1. OhBe1
    OhBe1 New Member
    Aug 10, 2012
    16
    Thinking about adding a skid plate, in case we actually get winter this year.
    Any experience with Rennline or other suppliers?
    #2 Crashton, Sep 17, 2012
    I have a Cobalt skid plate on my R53 & feel it is a good idea because of the cast aluminium sump. They don't bend they break.
    On an R56 you have a pressed steel sump & an exhaust that runs under it. The sump will bend not break. I'd be worried about hitting the skid plate on something & pinching the exhaust.
    Edit....
    That skid plate looks very well made. Wonder how much heat it will hold in on a turbo car?
    http://www.rennline.com/Aluminum-Skid-Plate-Mini/productinfo/U03/
  3. OhBe1
    OhBe1 New Member
    Aug 10, 2012
    16
    Yes, heat might be a concern - although the protection offered in either forward or backward directions is a plus.
    Cobalt's newer one might alleviate the heat issue, but Moss says it fits only 2007.
  4. OhBe1
    OhBe1 New Member
    Aug 10, 2012
    16
    Bump before I order a Rennline skidplate...
    That is a very well made skidplate. If you find things getting too hot under the bonnet after bolting it on you can always take a hole saw & add some cooling vents.
  6. Ernesto
    Ernesto Club Coordinator
    May 16, 2009
    687
    738
    Oracle DBA
    Skokie Ill
    Of course if you get one, you'll need to do a little paint work in case anyone is peeking under your car..
    ^ nice job, but I like mine scratched & scared.....
  8. UKCoopeR
    UKCoopeR Active Member
    May 21, 2009
    293
    109
    VA,USA and UK
    What crashton said, the numerous scrapes and one big gouge (exhaust fell off the car in front of me lol) on mine means it is working :)
    That is neat how it matches the stripes :Thumbsup:
  9. oldbrokenwind
    oldbrokenwind Active Member
    Oct 18, 2012
    196
    107
    Northern NV
    Got mine from Mini Mania a couple years ago - $145 plus shipping. Haven't installed it yet, 'cause it probably won't fit around my 3" exhaust, without some extra cutting. Then, if installed, I couldn't get around it to work on / fix anything it's protecting.
    It's still in it's original protective wrapper and shipping carton. Make me an offer?
  10. OhBe1
    OhBe1 New Member
    Aug 10, 2012
    16
    Which one?
  11. HurricaneDave
    HurricaneDave New Member
    Apr 9, 2012
    99
    34
    Tellecommunications Engineer
    Ball Ground, GA
    Oldbrokenwind do you know if yours will fit on a 12' Clubman S Automatic? Might be interested in seeing it.
  12. oldbrokenwind
    Oct 18, 2012
    196
    107
    Northern NV
    Bought it from Mini Mania in early 2011 --- part # G2NMA3041. You can go to their website, fill out the info for your car, then check the "will this item fit my car" box. Here's a link ---
    MINI Cooper - Skid Plate Stainless Steel Sump Guard - R56 Cooper
    HurricaneDave, looking at the other skid plates available, mine probably won't work in a 2012 clubman automatic. Since you're so close, if you want to check it out, send me a PM and I'll respond with an address / directions, etc. I have a good floor jack and a couple stands in my garage.
  13. HurricaneDave
    Apr 9, 2012
    99
    34
    Ball Ground, GA
    Everything I can find says it will not fit on a 12" Cllubby Auto. Thanks anyway oldbrokenwind!
  14. OhBe1
    OhBe1 New Member
    Aug 10, 2012
    16
    Got the Rennline skidplate in. Changed the acoustics a bit, no negative.
    Installing with the front on 6" high ramps was fun, supporting the plate on my chest and belly-breathing. Added a couple rubber washers to prevent scraping the frame.
    Gotta get some RaceRamps...
    Interested in how it changed the acoustics?
    That Rennline looks very well made. :Thumbsup:
  16. OhBe1
    OhBe1 New Member
    Aug 10, 2012
    16
    Not quite so much high frequency stuff, and especially does not sounds so, um, ticky-tacky on cold start.
    Now to get some decent tires.
