2nd Gen R56 Cooper S Smoking exhaust
Discussion in '2nd Generation: 2007+ R55 through R61' started by Lowsid3r, Oct 27, 2013.
  1. Lowsid3r
    Lowsid3r New Member
    Jun 19, 2012
    So hears the story. 2008 r56s just shy of 60k miles
    She had been consuming oil not sure of how fast. No spots on the ground. No smoke I actually could see or notice out of the exhaust.
    Changed the oil and installed a downpipe back exhaust. I got some smoke at idle and horrible new exhaust smell. But after a few days the bad smell diminished but the smoke was still there.
    Installed a catless downpipe 3 days ago.
    Smoke has gotten worse. It's usually big puffs at idle when the gas is blipped or I start to go. Sometimes when down shifting.
    It is gray with a slight blue hue. And I believe smells like burning oil. (Although I have never had a car burn oil so I am unsure)
    What should I be checking?
    Does it make since the stock exhaust was masking a problem?
    Pretty sure an exhaust system wouldn't cause a car to burn oil. Or could this be anything else? Thanks for the advice. I can put up a video if that's useful.
  2. pmsummer
    pmsummer Well-Known Member
    Apr 3, 2012
    570
    400
    Semi-retired planner
    #2 pmsummer, Oct 27, 2013
    :popcorn:
    I don't think I can help beyond the obvious.
    What brand of cat-back? A cheap painted one (or even a cheap 'stainless' one) could produce smoke as paint, shellac and/or 'cosmoline' burned off.
    Yes, removing a catalytic converter 'could' possibly unmask visible oil smoke (in theory). The job of a cat is to burn up unburned hydrocarbons (and they shouldn't be removed just because you can get away with it... they aren't there for decoration. /rant).
    Watch your oil consumption. Document loss (miles per quart).
    How many miles on the car? How long have you owned it?
  3. Lowsid3r
    Lowsid3r New Member
    Jun 19, 2012
    Invidia q300 cat back just under 60k Riss racing downpipe heat wrapped and coated
    They have been on the car now for about 500 miles. And have had the issue since putting them on. But before the install I had been losing oil.
  4. Lowsid3r
    Lowsid3r New Member
    Jun 19, 2012
    I have owned it for about a year now.
  5. pmsummer
    Apr 3, 2012
    570
    400
    If you were losing oil before, then the issue could be a combination of the things I've mentioned. Time for a compression check, I suppose.
