SneedSpeedShop R53 Brake Cooler Kit!!!
Discussion in 'Brakes' started by Sneedspeed, Sep 25, 2009.
  1. Sneedspeed
    Sneedspeed New Member
    Jul 16, 2009
    165
    56
    Racing cars
    Pfafftown NC
    SneedSpeedShop is now offering a brake cooler kit for the R53 Mini Cooper:
    When racing your MINI, it's just as important to keep your brakes cool, as it to keep your motor cool. After all, the faster you can slow down, the faster you can get back on the gas. The MINI Cooper Brake Cooler Kit air cools the brake rotors and calipers by ducting air through the front bumper to the brake assembly itself. The kit includes a 3" high-temp brake duct for each front wheel and aluminum brackets for attachment. Designed for US R53 MINI Cooper S, years 2002-2006. Requires fog light removal.
    ------------------NOW AVAILABLE----------------------
    Price: $198
    Call (336) 923-2044 to order.
    Ask for Preston
      File size:
      40.4 KB
      1,134
      File size:
      20.8 KB
      1,118
  2. cct1
    Is there a installation pdf for this (Need to see how much fender lining trimming is involved)? Might just pick this up, just trying to figure out how to install, and wether it will work with the TSW BDM kit, and clear the KW V2 coilovers without any issues....
    Also, is it easy to take the duct off (but leave the brackets in place)? Be nice to be able to remove it relatively easily when not on the track.
    Initially I thought this thing was a bit overrpriced, then I found out how much high quality three inch tubing costs...Then it suddenly didn't look so bad....
