Interior 1st Gen Spacing Out - Lookie what I made.
Discussion in 'Tuning and Performance' started by Nathan, Apr 6, 2013.
    I recently purchased one of these to replace the older Sparco wheel that has been on the car for a few years now.
    However, it is 10mm smaller in diameter at 320mm. The Sparco is 330mm. These few mm made me a knuckle dragger. There is a very slight drag of the knuckle over the stalks. To fix this, with a lot of help at the local metal shop a spacer was made.
    Monday I'll head over to the local Fastener Store to get some longer bolts so I can put the spacer in place.
  2. wmwny
    4,048
    2,246
    Nathan, I always just knew you were more than "spaced out"....:devil:
  3. BlwnAway
    BlwnAway Well-Known Member
    Nov 24, 2011
    474
    290
    In my best Carlin impersonation
    "Just a little farther out man."
  4. BlimeyCabrio
    First world problems
  5. versus
    versus Active Member
    Sep 8, 2009
    553
    87
    Mnnnn, flat bottom steering wheel. :Thumbsup:
  6. Metalman
    Nice work there Nathan....
    You need to fill out a job application at my shop sometime....:D
  7. Firebro17
    Wow, nice wheel!!! And to think they can get a full airbag into that tiny little center piece too... That is engineering beyond superior!
  8. agranger
    1,486
    You sure it was the wheel that made you a knuckle-dragger? :D
  9. LoLowe
    LoLowe New Member
    Jan 17, 2013
    64
    65
    Bonne Terre MO
    OH SNAP :D
  10. ChrisMCS04
    ChrisMCS04 New Member
    May 12, 2009
    92
    14
    Don't mean to bring up a old thread, but which omp wheel is this? Thinking about going this route once fixed seats arrive. Thanks
    No problem in dredging up and old thread with a new question.
    OMP SuperQuadro
    It is smaller than a an OEM wheel at 330mm in diameter.
    I shopped around and around for price before I bought it. Let me save you some time, everyone sells it within a few $ of each other. Just call TJ up a Detroit Tuned and get it from them.
  12. ChrisMCS04
    May 12, 2009
    92
    14
    Thanks Nathan! Will do.
    Hub from them as well?
