2nd Gen R60 Countryman Spark Plug Socket for R60?
Discussion in '2nd Generation: 2007+ R55 through R61' started by frankthetank77, Sep 2, 2014.
  1. frankthetank77
    Aug 26, 2014
    65
    27
    Marketing, graphic design, photography and video p
    Central California
    Hi all,
    First post here and i'm looking for a little assistance before I make any purchases. Can any of you shed some light on which mm size the multi point socket is for removing the spark plugs?
    Any help would be greatly appreciated.
    Thanks in advance,
    Frank
    Sears.com
    Change the plugs cold. 21 ft lb is the speck.
  3. frankthetank77
    Aug 26, 2014
    65
    27
    Central California
    SWEET! Thank you guys for the quick response...very much appreciated!
  4. frankthetank77
    Aug 26, 2014
    65
    27
    Central California
    Thanks a million!:Thumbsup:
  5. frankthetank77
    Aug 26, 2014
    65
    27
    Central California
  6. Way Motor Works
    Way Motor Works New Member
    206
    MINI Tuner
    Atlanta
    I have a long version of that socket a good friend gave me. No extensions needed. If you use an extension have a long pair of needle nose pliers handy in case the socket comes off the extension. You'll need the pliers to reach down & retrieve the socket. There is very little room down those plug holes.
    Edit.... I see Way has chimed in. If you buy from him get the long one, it will make life easier.
