Exterior 2nd Gen Splitter Dimensions? - R55
Discussion in 'Tuning and Performance' started by vistaracer, Oct 23, 2014.
  1. vistaracer
    vistaracer New Member
    Dec 31, 2013
    I am planning on making a custom front splitter for my R55. The one dimension that I am unsure of is how far out the ones that are sold by many of the aftermarket manufactures protrude. I was thinking of making mine in the 3" to 4" range. If anyone would let me know what dimension is on your splitter I would greatly appreciate it.
    Lynn
    I don't know but I did adjust the subject to help draw in more potential members with an answer.
  3. N2MINI
    N2MINI MINI of the Month
    Dec 4, 2009
    3,349
    575
    Sign Maker
    That dimension will depend on how/where it is mounted under the bumper and if you plan to use some kind of splitter braces to help hold up the front edge if sticking out very far. At speed it will catch a lot of air, and curbs when parking if not careful.. I have made some myself and some people trim the back side down so it doesn't stick out front as far and not use the braces, either they don't like the look or because they are alittle pricey.. They cost more then the splitter I make.. Depending on where you are measuring from I'd say 3'' or just over is a plenty but again it's all about the look your after..
  4. WINGS1
    WINGS1 New Member
    May 20, 2012
    19
    Solutionist Machinery provider to Woodworking, Cou
    Clemmons, NC
    You can't make one for what N2MINI charges and they're really nice!
  5. Metalman
    #5 Metalman, Oct 24, 2014
    I was fortunate to get my hands on a factory MINI Challenge Motorsport splitter.... It sticks out 3-9/16" from the front of the JCW bumper.... But more importantly it continues rearward and integrates into the GP2 front belly pan for seamless air flow which helps to generate vacuum.....
  6. vistaracer
    Dec 31, 2013
    Yes, I am planning on putting the braces on the front edge. Has anyone ever made it adjustable? I was thinking of one position for daily street driving and a second location for track days.
  7. vistaracer
    Dec 31, 2013
    I would agree, but I enjoy fabricating things and I am thinking of making it adjustable.
  8. vistaracer
    Dec 31, 2013
    That's perfect. Thanks to all. By the looks of these pics I should remove the vertical chin spoiler. I was think making a similar pan than extended back under the engine compartment. Or should I make the front edge of the pan flush with the bottom of the spoiler?
  9. N2MINI
    Dec 4, 2009
    3,349
    575
    Sign Maker
    You could make it adjustable by slotting the mounting holes, but you'd want to find an easier way of be able to make the adjustment then having to take to bumper cover off each time I'd think.. If you make it go back far enough under the car you could find some mounting points other then the bumper it's self maybe and then the slots would work fine. Granted the further you have something under the less air that will flow up to the engine compartment for cooling if it really matters...
  10. vistaracer
    Dec 31, 2013
    I was thinking of putting some sort of threaded insert in the spots that the bumper is mounted. That would make it easy to remove and/or adjust the splitter.
