MINI Spoiler broken, beeping sound won't stop
Discussion in 'Starting Line - New Member Introductions' started by Jan Zlotnick, Jul 3, 2023.
  1. Jan Zlotnick
    Jan Zlotnick New Member
    Jul 3, 2023
    #1 Jan Zlotnick, Jul 3, 2023
    2013 Roadster S Convertible, 100k miles.
    Took to 3 mechanics. Replaced wires, etc. Still beeping. Still showing alert on dash.
    Mechanics say it's the computer system that can only be fixed by dealer.
    Dealers want $2300 to fix.
    6,317
    Welcome to MA!
    A few questions for clarification.
    The thread title says spoiler broken. Is this a convertible or a roadster? The roadster has a spoiler.
    You said they replaced the spark plugs and wires. The car does not have plug wires it has coil packs. Did they replace the coil packs?
    What alerts are showing on the dash and what are the ECU codes it is showing?
    • Like Like x 1
    • Agree Agree x 1
  3. Jan Zlotnick
    Jul 3, 2023
    #3 Jan Zlotnick, Jul 4, 2023
    Thank you so much for your prompt reply!
    It indeed is a 2013 Roadster S Convertible.
    Yes, they replaced "coil packs"
    Alert on dash is indicative of spoiler stuck in up position. It has been manually pushed down but alert and beeping continue.
    No ECU codes are showing.
    Mechanics say only dealer can deal with the codes.
    I'm scheduled for a $2300 repair tomorrow. Should I go? I've been pursuing this for 9 months to avoid the $2300 cost.
    Thank you!
    Jan
  4. wmwny
    4,040
    2,242
    Welcome to M/A!
    I'm sorry, but I can't help you as all my MINIs are Generation One.
  5. Jan Zlotnick
    Jul 3, 2023
    #5 Jan Zlotnick, Jul 4, 2023
    Thanks, much appreciated....Anyone else out there who can help me....before i plunk down $2300 tomorrow/wed July 5 at a mini dealership that says there way is the only way? Thx :)
  6. Ernesto
    Ernesto Club Coordinator
    May 16, 2009
    687
    738
    Oracle DBA
    Skokie Ill
    Poking around on other sites, I saw mentions of a broken or corroded brown wire from the wiring sleeve on the right side in the trunk..
    Dont have personal experience with it.
  7. Jan Zlotnick
    Jul 3, 2023
    Thx, Ernesto! Appreciate your input. Yeah, we saw that wiring-sleeve note and covered that, too.
  8. MCS02
    6,317
    There is a code reader you can get that will read all the BMW codes. There are some independent shops that have everything to fix anything. It just depends on where you live. That is a big chunk of change but at this point I am not really sure how to advise you. If it is a probable with the ECU or one of the other related boxes that it talks to then you may be stuck with letting the dealer fix the problem.
    Sorry this is not much help. My R58 had a fixed JCW wing. but that had to be coded into the ECU.
  9. Jan Zlotnick
    Jul 3, 2023
    Thank you, good sir! Great info and I will check on this, even if it means postponing my appointment for tomorrow!
  10. 00Mini
    2,263
    Nine months is long time be dealing with an annoying problem but $2300 is a lot of money. It just seems to me that there has to be an independent shop / mini specialist who has the equipment to read a code.…and welcome to Motoring Alliance.
  11. Jan Zlotnick
    Jul 3, 2023
    Thank you. I'm looking for the Independent Mini Specialist! Anyone have a contact name ? Thx!
  13. Jan Zlotnick
    Jul 3, 2023
    Thank you sir!
  14. dNorman48
    dNorman48 Member
    Jul 24, 2019
    41
    22
    Howdy! Just curious if you were able to clear the beeping sound.
