2nd Gen R59 Roadster Spoiler Problem
Discussion in '2nd Generation: 2007+ R55 through R61' started by ChicagoRus, Jan 31, 2013.
  1. ChicagoRus
    ChicagoRus New Member
    Jul 12, 2012
    15
    IT
    Lombard, Il
    Just had my first real problem. Spoiler started to open at 50, but not completely. Then it started to beep with error telling me it couldn't come all the way up. I tried using the manual control but it wouldn't send it up, and it wouldn't go down. It's cold here with light snow and it's probably part of the problem. I'm sure the dealer will fix it.
    The bigger problem is the sound. The system is beeping (like when you don't wear your seat belt.) It won't turn off, constant beep-beep beep-beep, beep-beep beep-beep, over and over again. Called the dealer, no way to turn it off. I was thinking of ripping out the speaker, but that's probably not covered under the warranty... I'll let you know what they did to fix it.
  2. rum4
    rum4 Club Coordinator
    4,568
    1,475
    SC
    I hope they get it taken care of and let us know what the issue was.
  3. Justa Jim
    Yep,keep us informed.
  4. Mr. Jim
    Maybe some ice build up, can you get it in a warm garage?
  5. CHKMINI
    That's just one of the reasons I went to the JCW Fixed Spoiler. If you can't get it into a warm area to melt the ice you will need to see if you can clear out enough around the support hinges to get it to operate. The chime might be driving you crazy....just wait until it goes into limp mode to prevent you from driving faster than MINI thinks is safe without the spoiler deployed.
  6. itsmewutup
    itsmewutup New Member
    Apr 11, 2012
    351
    67
    Heated garages are nice for such things :)
  7. JECO
    JECO Active Member
    Apr 22, 2012
    228
    98
    Newsletter producer, retired DOT chief
    Crozet, VA
    I join with others in asking that you let us know how the problem was resolved. My Roadster better not start such shenanigans.
  8. Angib
    #8 Angib, Feb 2, 2013
    I had this happen in my Roadster and the bonging does drive you nearly mad. Particularly as it won't stop if you slow down below "spoiler-speed" or even stop altogether. If you stop and switch off the ignition, it doesn't start again - until you drive off when it continues, even if you don't go over 50.
    And the warnings on the Visual Boost screen are dire - I felt the "you will be struck by a thunderbolt if you drive anywhere" was a bit excessive.....
    I confirm that it causes no problem - once the spoiler un-freezes, it works fine and all the warnings go away.
    I think spoiler behaviour may not be the same in all cars/countries but in my car if I put the spoiler up manually when stationary, it stays up forever until I manually put it down, so that's one way round the problem, as long as I know to do it in advance - and don't mind looking like a ****head for having the spoiler permanently up.
  9. Spiney
    Spiney New Member
    Sep 6, 2012
    26
    9
    nr Boston, MA
    On my US car if I put the spoiler up when stationary then it stays up until I go above 50MPH then drop back down below 30-something, then it goes down (at least that's what I remember it doing, but I am getting old...).
  10. ChicagoRus
    Jul 12, 2012
    15
    IT
    Lombard, Il
    I took the car in yesterday. As soon as they were able to look at it they tried to lower it manually, and it worked. It had been in the garage for a short time, so I assume it was frozen. (Your suggestions of a heated garage may have worked.) They checked all the error codes but didn't find anything wrong. They also examined it for mechanical issues and couldn't find anything. They did say this was the first spoiler problem they'd seen. Because it's an active part, I'm assuming it won't be the last.
  11. JECO
    JECO Active Member
    Apr 22, 2012
    228
    98
    Crozet, VA
    Thanks for the latest info.
    Man that is a pretty poor design if a bit of ice & snow makes it go all wonkie. Didn't they test the coupester & roadster in winter conditions?
    Glad you got is sorted....
  13. Angib
    Actually, they probably didn't test in the right conditions as mine was definitely caught out by a 'British winter' - wet snowfall at maybe 31F, then a slight melt to 33-34F and a re-freeze to 29-31F. In most countries that would be a complete thaw in the middle or it would have been dry snow to start with - it's only hovering around freezing that seems to do it.
  14. CHKMINI
    JCW Fixed Spoiler...FTW
    That is a fairly good description of a lot of the winter weather in many parts of the US too.
  16. ChicagoRus
    Jul 12, 2012
    15
    IT
    Lombard, Il
    That's similar to what happened. We had an ice storm - worked that day, then a slight melt - worked that day, and then about an inch or two of snow and that's when I had trouble. I'm glad it's taken care of, but I'm not sure if it's the last - I'll update this thread if it happens again.
  17. Justa Jim
    I'm sure one of you vendors will come up with a "spoiler pre-heater" that will solve the problem. :Thumbsup:
    Here's a picture of the prototype undergoing testing. :biggrin5:
  19. Justa Jim
    Cool, looks like some of MM's work. :D
    Don't tell anyone, but it also is a walnut burner. :D
