2nd Gen R56 Cooper S Sputtering at 4500rpm
Discussion in '2nd Generation: 2007+ R55 through R61' started by itsmewutup, Sep 10, 2013.
  1. itsmewutup
    itsmewutup New Member
    Apr 11, 2012
    351
    67
    I have recently noticed the MINI sputtering right about when I hit 4500-5000rpm. Doesn't cause a problem for the most part due to the fact that I don't see those rpm levels often but I would like to know whats going on with it.
    2008 S Hardtop
  2. itsmewutup
    Apr 11, 2012
    351
    67
    How many miles on the car?
  4. itsmewutup
    Apr 11, 2012
    351
    67
    90k. Has a used motor in it that's been running fine up until the other day. Mileage on the motor is within a few thousand of miles on the car.
  5. MCS02
    What does it do when you go through this range under WOT? is it smooth or does it still sputter.
  6. Nathan
    Take a look at the spark plugs. When were they last changed?
  7. Dave.0
    Could be any number of things.
    Bad Gas
    Air Filter (rare)
    Needs new plugs or coil
    O2 sensor on its way out
    Crank Pull getting ready to go
    Dirty MAP or T-Map sensor
    I would start by replacing the plugs if the are the originals and a fresh clean tank or 93 octane gas and do a few runs WOT.
  8. itsmewutup
    Apr 11, 2012
    351
    67
    Haven't tried wot. Plugs were changed in April when the motor was put in. I never run anything but 93 in it. Had O2 sensor codes since I put a catless downpipe in (still a possibility?)
  9. itsmewutup
    Apr 11, 2012
    351
    67
    Update: As I'm on my way home from work this morning, it decided it was going to start misfiring all together. Pulling a cylinder 2 misfire. Currently at a gas station about 15 miles from my house and gonna check it out. Having a feeling it may just be a bad plug with the way its doing it. Will update later.
  10. itsmewutup
    Apr 11, 2012
    351
    67
    Well I feel like a complete idiot. Popped the hood open. Was messing around with the air box and noticed the coil wire had come unclipped. Guess the plug won't get any spark that way ;)
    On another note. It ran great the whole rest of the way home. High rpms and all!
    Another problem solved!
    Glad it was something that was rather simple and low cost to "fix".
  12. MCS02
    Glad to hear its fixed.
