1st Gen R53 Cooper S Stock airbox screws stripped?
Discussion in '1st Generation: 2002–06 R50, R53 & 2004–08 R52' started by bee1000, Mar 21, 2010.
  1. bee1000
    bee1000 New Member
    Dec 23, 2009
    176
    Marketing
    San Diego, California
    I got an Alta foam air filter and have now opened the airbox 3 times to install and then to clean it. The airbox top is held shut by 2 screws in plastic holes that don't seem intended to be used over and over again. Today one hole seemed like it was getting stripped. Is there anything to be done, other than buying a DDM box?
  2. dadsalfa
    dadsalfa New Member
    Dec 17, 2009
    15
    central Illinois
    fatter screws
    I have an 03S with stock airbox,so I don't know if this would work for you,but I used larger diameter stainless steel sheet metal screws when mine stripped out.
  3. bee1000
    bee1000 New Member
    Dec 23, 2009
    176
    Marketing
    Sounds that will work until those strip out, then I'll get bigger and bigger screws!:)
    I'm taking my car for service today and I'll check to see if it's possible to buy a new base to the airbox. I didn't see it (or the airbox at all) on Real OEM.
    On RealOEM its under Fuel Preparation System => Intake muffler
    RealOEM.com BMW R53 Cooper S SUCTION SILENCER/FILTER CARTRIDGE
  5. Eric@Helix
    Eric@Helix New Member
    1,257
    Shepherd
    Philadelphia
    Just get yourself some bigger sheet metal screws and carefully thread them by hand. When you feel slight resistance and you see that the screws are bottomed out, stop tightening. The OEM ones get stripped when people try to over-tighten them.
  6. ScottinBend
    Why use the box top at all?
    The Alta seals against the bonnet anyway.
  7. bee1000
    bee1000 New Member
    Dec 23, 2009
    176
    Marketing
    Thanks! Looks like an inexpensive part so I'll probably just have it replaced if necessary. I'm not really a DIY guy who would want to get into retrofitting it with new screws (and I don't particularly want to spend on a DDM right now - unless someone makes me a great deal at AMVIV).
    As I'm sure you know, tightening the screws clamps the lid down onto the filter to seal it shut. I try to get it tight-but-not-too-tight, but I suppose I failed. The metal screw into plastic ain't the best solution!
    I just have Alta's drop-in filter for the factory intake, not the Alta intake.
  8. ScottinBend
    Ahhhh........now I see. Stock air box was the clue, right?
    :blush2:
  9. bodinski
    bodinski New Member
    Jul 10, 2010
    12
    Stick half of a thin toothpick (or a small piece of insulated electrical wire) in the hole then install the screw. It should tighten down just fine this way.
  10. k-huevo
    k-huevo Club Coordinator
    159
    Pipe Creek, Texas
    I use a long 8-32 machine bolt and nut, place the nut on a strip of tape, screw the bolt through lid and bottom box until it barely exits, stick nut on bolt end and screw, remove tape when threaded, hold nut while tightening.
  11. Tüls
    Tüls New Member
    Apr 3, 2009
    438
    12
    The sky
    Yep, it's only plastic. Take it easy, they are just holding down a top, not holding in pressure. ;) :D
  12. Dr Obnxs
    Dr Obnxs New Member
    Jun 11, 2009
    1,158
    There are a lot of games you can play...
    you can fill it with epoxy and drill a pilot hole. There's the toothpic, there's Keiths suggestion. The screws are thread forming screws for plastic.
    I've got an extra base, I think. PM me if you want it for cheap.
    Matt
