Suspension Brakes Stock Spring Rates
Discussion in 'Tuning and Performance' started by KittyMini, Jul 6, 2011.
  1. KittyMini
    KittyMini Club Coordinator
    1,183
    Does anyone know what they are for the R56?
    I'm curious since I just put on new springs... how they compare.
    Thx.
    Your spring rates will depend on what options are on the car. Not all MINIs have the same springs. Hope that helps you.
  3. KittyMini
    1,183
    The only thing I know for sure is I did NOT have the sport suspension..... :confused5:
  4. grodenglaive
    grodenglaive New Member
    Apr 3, 2010
    313
    68
    Ottawa, Ontario
    You won't find the stock rates published anywhere, since they are progressive - the further you compress them, the firmer they get.
    Same goes for the aftermarket ones - hardly anyone gives the rates, even for the linear springs.
  5. KittyMini
    1,183
    That makes me feel better for having not found them :biggrin5:
  6. sdmidget
    sdmidget New Member
    89
    10
    Senior Planner
    Lancaster, PA
    Does anyone know which rear suspension is stiffer:
    Cooper w/ "sport" suspension
    - or -
    Cooper S w/ "stock" suspension?
  7. mini_racer
    mini_racer Well-Known Member
    Engr Manager
    TSW informed me a couple of years ago that the stock S springs on a late model R53 were 163 and the sport springs were 173. I certainly cannot validate those numbers though.
    My swag would be that the "sport" springs on a Cooper will be stiffer than the regular springs on an S.
  9. sdmidget
    sdmidget New Member
    89
    10
    Senior Planner
    Lancaster, PA
    The "stock" 2011 S does feel "softer" in the back end than my 2005 Cooper "sport package" did.
  10. KittyMini
    1,183
    I owned an R50 with Sport suspension and currently own an R56 S with the stock.
    Big difference. Although I think there would be a difference if both were stock. The r50s and 53s had a firmer, tighter set-up all around.
    I am slowly remedying this :cornut:
  11. sdmidget
    sdmidget New Member
    89
    10
    Senior Planner
    Lancaster, PA
    Guess I'll need to start "remedying" as well!!
    :yesnod:
  12. KittyMini
    1,183
    I already did a rear swaybar and lowering springs, but I'm still not happy. I'll be doing coil-overs this coming year :Thumbsup:
  13. sdmidget
    sdmidget New Member
    89
    10
    Senior Planner
    Lancaster, PA
    Swaybar is first on my list.
  14. KittyMini
    1,183
    It's a must! :Thumbsup:
  15. Rixter
    Rixter Well-Known Member
    Jun 14, 2009
    1,230
    79
    Technology Architect
    North of the 49th
    In Canada, the 2007, 2008 'S' + sport package came with the sport suspension, for what it's worth. I believe that was only for those 2 years.
  16. SMOG
    SMOG ZOOOOOMMMM
    164
    21
    Retired, twice...
    Port Orchard, Washington
    We have 2 MINI's. An '09 Cooper with standard suspension and a 19mm swaybar set in the middle hole. The car has very noticeable body roll in cornering compared to our other MINI.
    An '011 "S" with "Sport Suspension" and a 22mm swaybar set to the soft setting. This MINI corners pretty darn flat and rides like a brick in comparison. I am sure it could benefit from decent shocks, both of them could!
    The '09 Cooper is the around town car and the '011 is the fun one :biggrin5:
  17. Jason Montague
    :cornut: People get tired of hearing me say this but, the easiest way to tighten a MINIs suspension is to trash the heavy run flats and 24lb ea light weight(?:eek6:)17in MINI wheels(yeah the expensive ones that I paid extra for) for non run flats and after market 14-16lb wheels. After spiritedly driving this new set up, you'll check under the car to see what else they changed. On Margi(08 R56 MCS/JCWm sport suspension), the difference was amazing.:Thumbsup:
