1st Gen R53 Cooper S Strange clunking sound from the back
Discussion in '1st Generation: 2002–06 R50, R53 & 2004–08 R52' started by mrntd, Feb 4, 2014.
  1. mrntd
    When I go over bumpy roads or parking lots (lots of those around right now) slowly, 10mph or less, I get a clunking sound from the right rear. Once I'm up to speed there is no clunking. I've jacked up the car and checked for any loose suspension parts. I even re-compressed the suspension some and re-check. Nothing found.
    Any one have some new ideas?
  2. eMINIparts
    eMINIparts Well-Known Member
    3,751
    1,087
    MINI Parts Advisor
    Bedford NH
    Rear sway bar bushings worn ?
  3. CHKMINI
    It could be the top bolt on the rear shock. I had that happen to me once on my R53.
  4. wmwny
    4,048
    2,246
    I had exactly the same thing happen at about this time last winter and it was the top bolt on my right rear shock. Fortunately, Crashton came to my rescue with two rears he had taken from his S, and I am still driving with them.
    Had a clunk in the rear too, mine was sway bar bushings.
  6. Dave.0
    Like other have said rear shock bolt 75% of the time or rear anti sway bar bushings 25% of the time.
  7. ScottinBend
    In addition check the sway bar links.
    My MINI used to do that. Once the JCW suspension was installed it has been nice & quiet. So the fix is a new JCW suspension, Steven at eMINIparts.com can set you up. :Thumbsup:
  9. Justa Jim
    Had a similar thing. Lock nut on adjustable, rear, lower, control arm was lose.
  10. mrntd
    The bushings ware replace with the bar last spring. I'll check the shock.
    Thanks for the input
  11. Dave.0
    Strange clunking sound from the back? Remove dead body from trunk. :lol::ihih:
  12. Firebro17
    That'd more likely be a dying body, wouldn't it Dave?? :lol:
  13. Dave.0
    ahhh details..... :p
  14. Onramp
    Onramp Enjoy the Hiways of Life!
    Retired, mostly
    Renton, WA
    Pull the shock OFF and check the bushings there. I had a lower shock bushing crumble on an E30. Probably was making noise on higher speed bumps but just couldn't tell over the regular road noise. Go over each component including where the control arm mounts to the body. Disassemble if needed to check. Also - do you have anything stored in the pockets providing access to the rear lights? Thought I had something buttoned down in there but the little bungie broke and the tool bag was leaking tools...
  15. mrntd
    Dave, you must have added a trunk mod to your MINI because the best I could fit was a dead midget (little people; pc)sark.
  16. Metalman
    Check for Trunk Monkey's...
  17. Apok
    Apok New Member
    Jun 15, 2013
    776
    357
    Dead hooker wasn't quite dead. I hate it when that happens....
    I have a funny story about dead hookers and the auto show here in Columbus. No actual hookers were hurt to make this story.
