2nd Gen R59 Roadster Strange faint knock sound
Discussion in '2nd Generation: 2007+ R55 through R61' started by TG., Jan 22, 2016.
  1. TG.
    TG. Active Member
    Mar 2, 2014
    159
    70
    I hope it will get some visibility here but after 26-27k miles the car is developing a very faint clunk noise. It seems random in frequency but occurs regularly. It feels like something is loose somewhere on the suspension or drive train, but not always. It's a low deep sound slightly metallic, kind of a knock sound but not quite like a loose or worn out end-links. It's unsure whether bumps on the roads makes it any different or at all apparent.
    Any thoughts before I put the car on stilts this weekend to check it out?
    Any issues of which one might be aware?
    I just realize I should check the braces. The R59 has factory braces to keep the body stiff. I might as well check that out the link points.
    But if anyone has some ideas please chirp in!
  2. Qik
    Qik Well-Known Member
    Oct 27, 2015
    1,421
    670
    IT
    Atlanta-ish
    Recently had the same issue. Turned out to be a strut and mount. Parts are otw. I'll be swapping them out asap.
  3. Dave.0
    Do you have Sheldon Cooper locked under your hood? :lol: :lol:
    Penny , Penny , Penny
  4. JenLane
    JenLane New Member
    Jul 4, 2009
    Philadelphia, PA
    We had that issue with the R56. Turned out that there was a loose bolt holding on that heat shield on the cat.
  5. TG.
    TG. Active Member
    Mar 2, 2014
    159
    70
    Great to get some thoughts going. That will give me a few pointers to check things out. Too much snow today so both car are in the garage which leaves me no room to work. Maybe tomorrow.
