1st Gen R53 Cooper S Strut problems? 04 with 130000 miles
Discussion in '1st Generation: 2002–06 R50, R53 & 2004–08 R52' started by milda, Dec 21, 2011.
  1. milda
    milda New Member
    Dec 21, 2011
    When I hit a hard bump, my struts seem to bang hard now rather than dampen like they did when the car was new. There isn' any leaks and the front end doesn't bounce more than once when I push up and down on the front. Does it sound like the struts are bad?
  2. Justa Jim
    Welcome aboard. I can't answer your question, but with that many miles they could be. I know MINI has a number of parts that they say are lifetime, but what exactly is "lifetime"? Is that "forever" or the "lifetime" of the part? :D
  3. k-huevo
    k-huevo Club Coordinator
    159
    Pipe Creek, Texas
    Have a look at the area around the front strut top for deformation and/or a torn guide support bushing. Strut Mushrooming - MINI Cooper Forum - MINI2 Mini Cooper Forums
    Compare how far the dust cap extends upward from one strut to the other. The guide support bushing can collapse from below and not show a visible tear above.
    ^ Yes like k-huevo said. At that mileage I'd say the struts are a bit past their prime. They can be bad & not show any leaking. The old bounce the car test works better on cars with soft springs like old American land yachts not so mush on a car with stiff springs like your MINI.
    Welcome to M/A milda. :)
  5. beken
    beken Well-Known Member
    Jan 13, 2010
    1,405
    1,829
    Delta, BC
    Actually, have a look at your front suspension bushings. It's likely time they are replaced if they haven't been replaced yet.
  6. SNEEEZY - Erika
    1,212
    116
    Female
    Does anyone know the "mileage life" for Megan coilovers?
  7. Way Motor Works
    Way Motor Works New Member
    206
    MINI Tuner
    Atlanta
    Sounds like they are worn out. The Koni FSD's are a great cost effective replacement.
  8. Minidave
    4,596
    Check the lower control arm bushings too......at 130K on an '04 I'd be surprised they're not completely knackered....
