1st Gen R53 Cooper S Supercharger help? :D
Discussion in '1st Generation: 2002–06 R50, R53 & 2004–08 R52' started by TimmyTurner, Aug 8, 2015.
  1. TimmyTurner
    TimmyTurner New Member
    Aug 6, 2015
    16
    Las Vegas
    Hey guys! I noticed this morning at Cars and Coffee that my supercharger is making a slight metal on metal noise. It's not super loud or bad, just a very slight rattle. I was wondering if changing the oil in it would help make that go away or if I would need a new supercharger. thanks :)
  2. ZippyNH
    Many SC rattle a bit...the lobes are very tightly fit...can sound a bit like an eggbeater....
    The "bad" sound is more like a draggly chain sound....
    One tip...SC rattle and throwout bearing rattle is sometimes confused...
    So sit in the car...push the clutch in...see if you sound goes away...if so..its the clutch/throwout bearing...
  3. TimmyTurner
    Aug 6, 2015
    16
    Las Vegas
    it's definitely the supercharger. it sounds like metal on metal, but the car doesn't overheat and it's not super loud. not sure. I'll continue to drive it until something breaks i suppose.
  4. ZippyNH
    If the SC is low enough on oil to have metal on metal unlubed gears, then the seals are bad...just changing/adding oil, about a 5 hr job (for a pro, more for a diy'r) plus about $50-100 in gaskets+lube would be a waste IMO...
    If you are going to dig deep enough to remove a SC, IMO, you should get it overhauled or exchange it...I think I have seen more threads on post diy "fixes" having to do with vac leaks and other issues here than it has saved folks...
    If it is a SC gear issue it will worsen rapidly...but many rebulders INCLUDE the PTO rebuild in the basic cost...they SHOULD since this is WHY many SC fail....and while you are at it...swap the WATERPUMP too...
    But enjoy your car, have fun, and give it some time IMO. Many folks go temporarily OCD reading about issues on forums with a new car...
    Sure some cars are sold cause issues might be looming...but often folks get worried about a new car...
  5. MCS02
  6. TimmyTurner
    Aug 6, 2015
    16
    Las Vegas
    I was looking at the one that way sells for 1100 bucks. Would the detroit one be a better choice?
  7. MCS02
    I'm not sure. I have delt a lot with Chad at DT. He is a great guy. I believe Way has a good reputation too I just have not delt with them before.
  8. TimmyTurner
    Aug 6, 2015
    16
    Las Vegas
    I'll keep that in mind. the car drives fine and doesn't do anything weird. Just that slight rattle. It's not as loud as others i've heard. So i'll see what happens in two months. Lol
  9. ColinGreene
    ColinGreene Well-Known Member
    438
    293
    Orange county Ca
    Use a long screw driver up against the nose cone to listen to it, see if its the supercharger for certain.
  10. TimmyTurner
    Aug 6, 2015
    16
    Las Vegas
    I used a stethoscope :) it's where the noise is coming from, but I can't replace the supercharger quite yet. The mechanic in our mini club said to just drive it for a while. There's not much I can do to get away from it.
  11. BlwnAway
    BlwnAway Well-Known Member
    Nov 24, 2011
    474
    290
    #11 BlwnAway, Aug 10, 2015
    Unless it's really bad/loud/noticeable, you probably have plenty of time, I drove mine for nearly 20k before I changed it, just keep an eye on it until you don't feel comfortable driving it. As mentioned before, watch your temp, the noise is most likely the W/P gears, (99% of the time) and yes the sound will transfer to the nose cone, but because this is normally the issue, besides overheating, you won't damage your motor itself even if you drive it until it drops, any metal shavings will stay in the housing.
  12. fishmonger
    fishmonger Well-Known Member
    May 13, 2015
    984
    769
    Madison, WI
    change the oil in the thing and get another 50k miles out of it. Not too hard to do. Takes a day of tearing into it if you've never taken the front end of the car apart. Watch ModMini's SC oil change and front end service videos on Youtube to give yourself some confidence that you, too, can do this in your own garage. Other than the #%@! intake tube it was pretty easy. Having the right tools and wiggle extensions helps. I'll be changing my SC oil every year from now on.
    While in there, fix the usually leaky crank position sensor O ring and dip stick O-ring, replace the water pump, and then bolt it all back up.
  13. TimmyTurner
    Aug 6, 2015
    16
    Las Vegas
    The problem for me is finding somewhere to do it. I'm missing a few tools but I can borrow those. hopefully it'll last another month or so and then i will just replace it with a blower from the 05-06 mini :fingerscrossed:
  14. BlwnAway
    Nov 24, 2011
    474
    290
    Just remember, while the '05 and later SC's are slightly mite desirable because of having coated rotors, they still suffer from the same issue, anything I've 125k or so will still give you the same problem, if you can't do as "Fish" suggested, just start putting money side for a rebuilt unit, you'll be looking at at least another 100k out of one of those.
  15. TimmyTurner
    Aug 6, 2015
    16
    Las Vegas
    So I poked around the car a little more today, and I used a stethoscope to listen. The rattle isn't on the supercharger (yes my mistake). its most prominent on the tensioner, which is brand new. Dad said it sounds like it's coming from the left side of the motor where the pulleys are. It's definitely not timing chain rattle. He thinks it's the idler pulley. Any idea on what a dying idler pulley sounds like? its not a squeal. Just that chattering noise. He said the pulley looks like it's trying to move when i rev the car slightly.
  16. ZippyNH
    Two questions...
    When you rev it to near redline...does it squeal a bit?
    I'm wondering if you have a belt that might be too loose...and
    What size belt do you have?
    I generally suggest a 532 with a 17%, a 535 with a 15% if you have the stock size crank damper...
    A failing idler should sound like a bad bearing..whirr...
    Guess it's possible the little gas strut on your new damper failed...infant mortality....
  17. clifforddward
    clifforddward Active Member
    Dec 2, 2013
    104
    76
    Cary, North Carolina
    There are a bunch of aftermarket and OEM vendors of the belt tensioner for the Mini, some apparently better than others judging by posts over the years...always buy from a reputable dealer...and the idler pulley is an often overlooked item. I replaced mine at 95k miles although it had no symptoms...when I removed it I noticed it was certainly worn compared to the new one that replaced it...I should have replaced it earlier I think.
    As so many things on our Minis, better to replace before failure...cheap insurance to keep you off the side of the road...
  18. TimmyTurner
    Aug 6, 2015
    16
    Las Vegas
    I have a 15% With the 535 belt. When you Rev the car that high it just makes normal noises. It's a definite rattle. It's loudest on the belt side but I don't think it's timing chain. I'm not sure. I'm quite stumped. :confused:
  19. Eric@Helix
    Eric@Helix New Member
    1,257
    Shepherd
    Philadelphia
    The idler pulley is easy and cheap to replace. That's one part I'd almost recommend just throwing at the car to eliminate it from the list of potential noise-makers.
    A note on diagnosing a supercharger: the M45 charger is a very noisy piece, even when brand new. If you're using a stethoscope or pry bar to listen to bearing noise, you might be fooled by all of the noise.
  20. TimmyTurner
    Aug 6, 2015
    16
    Las Vegas
    I replaced the belt tensioner with an oem part because I get discounts at the local dealers. I'm just really stumped. It's a grinding noise that you only hear on the tensioner. Nowhere else. It's definitely on that side of the motor, but I don't think it's timing chain. :confused:
