2nd Gen JCW Surging
Discussion in '2nd Generation: 2007+ R55 through R61' started by minirab, Feb 26, 2017.
  1. minirab
    2012 R58 JCW (N14) with a RMW tune. This started
    a little while ago. When using 1/2 throttle or more
    the motor surges from 2500 rpm to 5000 rpm then
    the surging stops and pulls like it should. This
    surging is very rapid, at least once a second. The
    car doesn't throw any lights. I do have a Sprint
    Booster on it so I set it back to the stock map think-
    ing that might be it but no dice. It still does it. Any
    thoughts? Also, the car has a Scanguage and the
    map goes up to 34.0 but no higher. Is that telling
    me something?
    Thanks.
    Just a wild guess, Is the throttle body clean? Have you checked all your vacuum hoses? Bad sensor MAP or TMAP I can't remember what the R56 has.
    Sorry not much help
