2nd Gen R56 Cooper S Suspension decision.
Discussion in '2nd Generation: 2007+ R55 through R61' started by miniwop, Oct 13, 2012.
  1. miniwop
    miniwop New Member
    Oct 6, 2012
    25
    MIni nub here, please have patience.
    After much research and hours of Forum reading I decided to go for the TSW springs (3/4 inch drop) and a 19mm sway bar. I'd like your opinion on this set up.
    I do not track or AutoX nor am I planning to. This is a daily driver, I am only looking for a little better handling performance and a better stance, slamming is not for me. And while I have your attention: what setting would you recommend for the sway bar? Will the TSW strings negatively affect the ride considerably? The car is not what I would call very comfortable as it is. I do not have 22 yr old kidneys anymore and in San Diego we don't have potholes, we have canyons. Thank you all for your time.
  2. kent kanipe
    kent kanipe New Member
    Oct 21, 2010
    79
    17
    Corvallis, Oregon
    miniwop, I have the same setup. The ride is much better, in curves very flat. I set the bar in the middle and have not changed it. I tracked at Mini Thunder last year and the setup did very well, made runs to AMVIV and MINI in the Mountains from Oregon and it travels all day very well. For me the stance is just right.
    Kent
  3. ScottinBend
    I have the same setup on my R53 and can say the same.
  4. Jason Montague
    :cornut: This is a very popular set up but don't forget the most important thing to do: get a front end realignment after the 'lowering.':Thumbsup:
    Add camber plates & adjustable rear arms if you want to add good tire wear to the mix.
  6. Firebro17
    Miniwop... You did your homework well.......
  7. miniwop
    miniwop New Member
    Oct 6, 2012
    25
    Gentlemen, thank you so much, I do appreciate your input. One final question: how does the mod ride compare with the stock ride?
    Thanks again.
  8. miniwop
    miniwop New Member
    Oct 6, 2012
    25
    OK this is where my ignorance comes out: I've heard and I think I know what camber plates are...Do I need them on all four corners? And what are adjustable rear arms? Thanks for your time.
  9. Jason Montague
    #9 Jason Montague, Oct 13, 2012
    Camber Plates- Are only used on the Front and installed on the top of the Strut tower. There are fixed plates(cheaper but limited adjustment) and adjustable(more expensive and wider adjustment range). They allow for custom Camber and Toe settings not possible with the factory set up. They are not at all needed if factory settings can be achieved after lowering the car(lowering 1in or less). However, racing types often have special camber and toe needs. The more that the car is lowered, the more likely one is to need camber plates to achieve correct front end geometry or add more aggressive camber and toe settings.
    Adjustable Rear Control Arms- Factory rear control arms( fixed and therefore very limited adjustment capability),2 to a side, upper and lower(usually only upper adjustibles are installed to add more aggressive positive camber settings), maintain proper rear suspension geometry(camber and toe[toe adjustment,> factory, need upper and lower adjustable rear control arms). Again, if one's lowering springs aren't too aggressive(1in or less) then proper realignment can be done without adding adjustible control arms.
    Where all of this comes into play is when owners want to lower their car and readjust camber and toe to accomodate a more aggressive driving style(racing etc). The Mini with the Sport Suspension, Light Wheels, and Non Run Flat Tires is already capable of being driven better than the great majority of us can drive her. People with lots of money and professionally racing, do it all. People like me on a limited budget and mainly spirited street, none of it is needed. The car will already drive better than we can drive it. Mods are fun but in most cases not needed.:Thumbsup:
  10. miniwop
    miniwop New Member
    Oct 6, 2012
    25
    Jason, thanks so much. I guess with a 3/4 inch drop I won't need all the extra hardware and $$. Much appreciated.
  11. Firebro17
    The ride on my car improved. I run the OEM sport struts/shocks with these springs... Largely because I didn't want to compromise the ride on top of the added firmness of the springs. I nearly went for the Koni FSDs, and in some respects, I wish I had. However, I had uncertainty as to whether or not the ride height would be affected and as to negatively impacting the guarantee from Koni. I wanted the car lower without too much of a ride comfort compromise. I believe I did well in my decision, for my purposes...
    You can get by with the OEM rear control arms too if you so choose. I did so for over a year. I later opted to replace the lower arms with a pair from Megan. Very nice product and provides for added camber adjustment to your desired liking.
    Spend the money on a good alignment when done with your mods. When you lower a MINI you add negative camber. Negative camber on the front will cause your MINI to toe-in. That means it will handle like a pig without an alignment to straighten things out. There is a bit of adjustment available in the rear to get rid of some of that added camber. The camber added to the front is livable, but the toe-in is not.
  13. miniwop
    miniwop New Member
    Oct 6, 2012
    25
    Thank you, I am definitely planning on an alignment. You said spend the money on a good alignment...versus a bad alignment? Sorry, I am a nub.
    Should I ask for something in particular when I go and have it done?
    Thanks again.
    Yep spend on a good one.:p Not all alignment shops do a good job. Ask around locally for the best place. You want a shop that will do custom alignments, some will only go by what their book tells them. On your lowered car it won't work well. Good luck. :Thumbsup:
  15. Metalman
    What is your location?
  16. Dave.0
    Lots of very good advice in this thread by people that know what they are talking about.:Thumbsup:
    For once I agree with everyone and have nothing to add. :eek6::lol:
    Let the modding begin.:devil:
  17. Jason Montague
    :cornut: Coming from you Dave, Thanks.:biggrin5::Thumbsup:
  18. Firebro17
    If you're in Central California, I know the best there is for your allignment.
  19. miniwop
    miniwop New Member
    Oct 6, 2012
    25
    I am in San Diego, does anyone know a place that will do the install AND the alignment? thanks for your time.
  20. Firebro17
    Just drive the car up here after you finish the work, or have my friend do the job for you. You're welcome to hang out and stay with us if need be. If you do the work yourself, the distance driven between San Diego and Fresno won't affect your car before an alignment. PM me and I'll give you David's contact info...
