1st Gen R53 Cooper S Suspension questions
Discussion in '1st Generation: 2002–06 R50, R53 & 2004–08 R52' started by narvarr, Jul 1, 2015.
  1. narvarr
    narvarr Active Member
    Nov 8, 2014
    183
    116
    Maintenance Tech
    Rowlett, Tx (Dallas Metro)
    I'm starting to plan out my suspension upgrades and the one piece that I'm not sure about are the shocks. Other than the Koni yellows, what other shocks pair up well with Swift springs? I'm not looking to go the CO route as this is a daily driver and never sees any time at the track. Also, I have plans to install the IE fixed camber plates, but read they were not suggested for use with lowering springs. If that's true do I need to get the adjustable plates instead?
  2. Agbullet25
    Agbullet25 Member
    Apr 2, 2013
    40
    23
    Central Texas
    You can check and see if the Bilstein sport shocks are made for the R53. They're valved to work with aftermarket springs, but they don't have the adjustable nature of the Koni yellows (could be a benefit depending on your intended use).
  3. CHKMINI
    Go with the yellows. I've had lowering springs and yellows on two different MINI's and it's a great street set up.
  4. MCS02
    6,280
    Is there something other than Koni yellows??:D
  5. DixonL2
    DixonL2 New Member
    274
    A bit north of the 'burgh, PA
    Why not Koni Yellow? Proven solution.
    There are bilsteins, and new OE shocks (which are actually pretty decent), but honestly, the Yellows are the way to go. that said, some have also enjoyed the FSDs, I've never tried 'em.
